RV.Net Open Roads Forum: Tech Issues: Axle-less trailer suspension: pros and cons?
 > Axle-less trailer suspension: pros and cons?
profdant139
Posted: 02/03/22 09:43am Link  |  Quote  |  Print  |  Notify Moderator
This goes into the "you learn something new every day" category -- I never heard of this before. It seems like a good idea -- improved stability and ground clearance, especially for those of us who take our trailers off pavement. Not cheap, but might be worthwhile?
If you have any additional insights, I'd be very interested in your comments!
Axle-less suspensions
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
bgum
South Louisiana
Posted: 02/03/22 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Has been used for years on light duty sailboat trailers. They must be somewhat dependable.
Jim-Linda
Livingston, TX
Posted: 02/03/22 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Mor/ryde IS has been in use for many years...no axles
Jim
WNYBob
Tonawanda, NY
Posted: 02/03/22 10:35am Link  |  Quote  |  Print  |  Notify Moderator
The frame must be cross braced! Without an axel to spread the lateral forces the frame can twist.
Other than that, they are a good suspension.
Posted: 02/03/22 11:14am Link  |  Quote  |  Print  |  Notify Moderator
In the context of RV trailers, the average rv trailer frame would have to be designed much heavier and stiffer to resist the stresses imposed by this product. Nothing wrong with the product itself, IMO.
profdant139
Posted: 02/03/22 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Is cross-bracing something that can be done when upgrading to the new axles? Or is that something that has to be built in to the original frame?
BarabooBob
Baraboo, WI
Posted: 02/03/22 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Dexter makes their Torflex axles have a frame member that mounts up against the trailer frame to provide strength. The arms of the suspension are mounted on the end of this frame member.
These axles have been used on light, medium, heavy, and super-heavy duty trailers for years.
My snowmobile trailer has a Dexter Torflex axle to provide better snow clearance.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
n0arp
FT
Posted: 02/03/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
MORryde IS, mentioned previously in this thread, requires it, and it's part of the install process.
philh
Belleville MI
Posted: 02/03/22 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I installed Morryde IS on a brand new 5th wheel. NOT CHEAP, but worth every penny. It made a huge improvement on towing.
MNRon
Tennessee
Posted: 02/03/22 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
MORryde IS
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
