patperry2766
Saginaw Texas
Time for a change and have used OEM filters in the past. I know that Fleetguard makes Mopar, but has anyone ever tried a non-OEM brand. I'm not talking a cheap Amazon knockoff, but something like Baldwin or Wix?
There is a backorder on Fleetguard and alot of places say there is a backorder on Mopar, which makes sense as well. The Mopar has 3 micron filteration rating, while the Baldwin advertises <4 filteration. Truck is still under warranty. Should I just stick to OEM and wait till they get them is stock?
I'm about 2K miles over my change interval
Courage is the feeling you have right before you fully understand the situation
Wix has a nominal micron rating of 2. Nominal, absolute, schmabsolute, whatever. They’re good filters.
FishOnOne
The Great State of Texas
I remember when I had my 05 6.0PSD and the Wix fuel filters didn't have the aqua block material on the primary filter and would allow water to pass right through the filter. After learning that, I only purchase OEM fuel filters and never had a fuel system problem with a combined 420k miles on my current and previous truck.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
ScottG
Bothell Wa.
Yes, I have tried Wix for air filters, Napa Gold and another I don't remember for others.
They all pale in comparison. The air filters will pull down my filter minder a little even when new - showing that they simply don't flow as well. The fuel filters don't have nearly as many pleats (Napa Gold was worst) so wont last as long and the FG's oil filters use their straopore tech (read about it) and are priced competitively so no reason to use others. I have also seen the oil filters cut open for comparison and the FG always have more pleats, better bypass hardware and are generally heavier built and better quality.
I would like to save a buck but found it just isn't worth it.
What ever you do, don't use a Fram oil filter. They are known to kill these engines and Ram even has a TSB to identify the damage they cause.
Cummins12V98
on the road
If you want your warranty to stay intact use MOPAR, RACOR or FleetGuard!!!!!!!
Geno's Garage has everything you need. The engine mount NanoNet Mopar is backordered til 2/15, they have the MOPAR and Racor under bed filters for the 13-18's and 19's thru 22's in stock.
GREAT people to buy from!!!
genosgrage.com
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
patperry2766
Saginaw Texas
Yeah, got a Fleetguard under bed filter, but I ordered the wrong Mopar engine filter without the Nanonet by accident. Had to return that one. Prices have gone up considerably over the year on filters...and diesel...and everything else
goducks10
There
Cummins12V98 wrote: If you want your warranty to stay intact use MOPAR, RACOR or FleetGuard!!!!!!!
genosgrage.com
x2. I couldn't swallow the dealers price of around $300+ for two filters changed so I bought them from Geno's and did it myself.
amxpress
Clayton, NC
Using a Wix filter will NOT affect your warranty.
I’ve used Wix in my 6.7 when I couldn’t find Mopar.
No problem.
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
Cummins12V98
on the road
goducks10 wrote: Cummins12V98 wrote: If you want your warranty to stay intact use MOPAR, RACOR or FleetGuard!!!!!!!
genosgrage.com
GOOD MAN!!!
Cummins12V98
on the road
amxpress wrote: Using a Wix filter will NOT affect your warranty.
No problem.
I guarantee you that the WIX is NOT as good of a filter as the MOPAR/FleetGuard. I sure would NOT bet my warranty on it.
I recently had to prove proper filtration on a MaxCare warranty claim. So let us know how that works for you if you have a filtration related warranty. Chrysler does NOT screw around anymore.
