RV.Net Open Roads Forum: Class A Motorhomes: 2013 Itasca V-10
 > 2013 Itasca V-10
wtmtnhiker
New Hampshire
Posted: 02/11/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Looking at a 2013 Itasca Sunstar motorhome with a Ford V-10. It has a little over 37,000 miles on the drive train. Assuming it was well maintained can I expect allot more life out of the drive train or move on to something else? Thanks to all for reading.
Thanks
bgbassman(bluegrass bass man)
pianotuna
Regina, SK, Canada
Posted: 02/11/22 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
My 2005 v-10 has over 110,000 miles on it. So far one mass flow air sensor has been replaced.
This is not proof--but is anecdotal evidence.
Regards, Don
Dutch_12078
Winters south, summers north
Posted: 02/11/22 11:06am Link  |  Quote  |  Print  |  Notify Moderator
For a 2013 Ford F53/Triton V-10, 37,000 miles is little more than broken in. That's not much over 4,000 miles/year, so the RV likely hasn't been "rode hard and put away wet". Our 2001 F53 based motorhome has just over 72,000 miles on it, and the closest thing to a "major" repair it's had was having a new starter installed last year. Everything else has been routine normal maintenance items.
Dutch
2001 GBM Landau 34' Class A
Dale.Traveling
Newport News, VA
Posted: 02/11/22 11:54am Link  |  Quote  |  Print  |  Notify Moderator
If the maintenance schedule has been followed there is a strong possibility the chassis will out last the house that is built on it.
2006 Hurricane 31D built on a 2006 Ford F53
dodge guy
Bartlett IL
Posted: 02/11/22 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
The V-10 has been known to go well over 500k miles with proper maint. The 5 speed is also very solid and dependable as well as the rest of the chassis.
Have it inspected before purchase.
With that low of miles make sure to run the generator so you can see if it can handle the loads put on it from the ACs and other AC appliances. It shouldn’t surge when running under load or at idle. If it hasn’t been serviced it will need it. Low hours on a generator are not a good thing, they need to be used or they have running issues. My 2012 has 450 hours on it. You will want to see at least in the upper 200’s for hours.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Heisenberg
West Texas
Posted: 02/11/22 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
My opinion would be that it has not been used too much unless it has been lived in. Not enough use is hard on generators and engines and other mechanicals.
I am going a little above just the v-10. The V-10 has been spectacular since the early models.
2013 Winnebago Sightseer
2017 Colorado
way2roll
Wilmington NC
Posted: 02/12/22 06:14am Link  |  Quote  |  Print  |  Notify Moderator
The chassis and drive-train are bulletproof and will outlast the house if properly maintained. In a 10 year old coach I would be more concerned about hoses, slides, roof seams, generator etc. Just make sure you or a competent person does a through inspection.
* This post was edited 02/12/22 07:05am by way2roll *
dodge guy
Bartlett IL
Posted: 02/12/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I second all of this. The entire house portion needs to be inspected closely,
wtmtnhiker
New Hampshire
Posted: 02/14/22 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for the helpful replies. Coach is at a dealership and I'm going to look at it tomorrow.
dodge guy
Bartlett IL
Posted: 02/14/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds good. just look closely for water damage, Under all windows and at the corners near the floor. As well as the roof seems.
The chassis portion will be just like a car. check all fluids and make sure there are no lights on.
Personally knowing the chassis. I would be more concerned about any "house" issues.
 > 2013 Itasca V-10
