RV.Net Open Roads Forum: Tech Issues: 100 a/h Lithium Battery for $21?
 > 100 a/h Lithium Battery for $21?
ScottG
Bothell Wa.
Posted: 02/14/22 08:54am Link  |  Print  |  Notify Moderator
I would not: De-reviews
Sandia Man
Rio Rancho, NM
Posted: 02/14/22 09:32am Link  |  Print  |  Notify Moderator
Under $400 for 2 pairs of GC2 batteries, we purchase all our RV batteries here although we tend to catch them on sale saving $100 on a set of four. Average about 8 years on a set of GC2 batteries before trading in although they still have power left in them. Love the new battery tech but will stick with what has worked well for us over the last 3 decades, I spend more on fuel in a single out of state trip for what it costs to have 8 years of reliable 12 volt reserves.
Owens River area
Posted: 02/14/22 10:16am Link  |  Print  |  Notify Moderator
"Am I right that the lithium don't need to be vented like the golf carts would?"
Correct. No vent needed. Can be mounted inside your RV. Lithium IS reliable.
rlw999
Washington State
Posted: 02/14/22 02:38pm Link  |  Print  |  Notify Moderator
I wouldn't buy super cheap lithium batteries to put into my RV unless they were in an outside compartment far from my living area.
Lead Acid batteries don't worry me - as long as you don't short them out and you vent the hydrogen, lead acid batteries don't have a catastrophic failure mode.
Lithium batteries rely on temperature and voltage monitoring for safety - overcharging will result in catastrophic failure. The charger should prevent overcharging and will usually monitor temperature too, but the BMS inside the battery is the safety system of last resort preventing you from having a battery explosion.
Safety systems like that are the last place I want to save a few dollars, or even a few hundred dollars. I'll gladly pay for name-brand batteries if it means that I'm less likely to have the battery beneath my bed explode because my charger tried to overcharge them.
naturist
Lynchburg, VA
Posted: 02/14/22 03:25pm Link  |  Print  |  Notify Moderator
There is no way any legit business can sell multiple 4-unit pallets of items normally costing $600-$1,000 EACH items for only $82.99 for all four. While there is a microscopic chance someone could stumble onto such a deal in the case of someone with them just wanting to get them the heck out of the garage/shed/extra bedroom, I think you have to stretch your chances beyond all possibility in order to find a legit deal of the sort offered in the ad, which, btw, has been showing up on my Facetube feed frequently of late.
I have not bitten because I am certain enough it is a scam to not bother risking, er, throwing away $82.99.
Posted: 02/14/22 04:05pm Link  |  Print  |  Notify Moderator
Someone dissassembled a battery not unlike these (low cost) and found.... Some things were not. precisely, as advertised.
That said. it was still a good battery.
OkieGene
oklahoma city
Posted: 02/14/22 04:10pm Link  |  Print  |  Notify Moderator
Was this ad on facebook? Wanting you to pay by paypal? If so, SCAM!!!
Run!
otrfun
On The Road
Posted: 02/14/22 04:56pm Link  |  Print  |  Notify Moderator
I believe you may be confusing lifepo4 with other less stable lithium chemistries. Lifepo4 batteries are very stable and safe. They will not explode when overheated or overcharged. No significant thermal runaway issues. They also don't emit or off-gas any kind of deadly fumes like a lead cell either. Completely safe to use underneath your bed. What's not to like?
rlw999
Washington State
Posted: 02/14/22 05:27pm Link  |  Print  |  Notify Moderator
LiFePo4 batteries are *safer* than other chemistries, but still require an operational BMS to make them safe. And in some cases, the BMS in the battery itself can fail and cause a fire.
I have a huge lithionics battery under my bed, but I trust them to design a good battery and recall it if there are problems, they can't afford the bad press if there's a fire.
But if I buy a battery from some unknown reseller, the company may already be out of business (or running under another name) by the time a problem is discovered.
jaycocreek
Idaho
Posted: 02/14/22 06:22pm Link  |  Print  |  Notify Moderator
When I bought my last 100ah lifepo4 for a little under $300,the guy told me that lithium batteries are going up in price including there's...It did bit there still are a few good bus out there..Last I looked,Chins was $309 and there rep said that they use GFB cells,same as SOK..
Lifepo4-380ah/Lithium NMC-140ah/Solar-400 watts/Wagan & Giandel PSW/Engel & Iceco 3-1 compressor fridge freezer/5K Window AC/Honda 2K
