RV.Net Open Roads Forum: Class A Motorhomes: Splendede washer lint filter cleanout
 > Splendede washer lint filter cleanout
larry cad
ohio
Posted: 02/14/22 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Curious if anyone has come up with a good idea for cleaning the washer lint filter?
When we unscrew ours, we always get a flood of water onto the floor. The water runs out the filter hole, and down the front of the machine, to the floor.
We try to catch it with a towel, but a lot gets by us.
Wondering if there are any suggestions out there.
Our Travel Blog
bgum
South Louisiana
Posted: 02/14/22 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
How often do you clean it. Is it possible to blow out the line or install a pre-filter filter that is easily cleaned?
larry cad
ohio
Posted: 02/14/22 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Really don't care to try to remove the washer. It is in close quarters, and weighs a ton.
I was looking for something I could do to the discharge end, as in the part just inside the little door that covers the filter.
I can open the little door fine. Then I have to unscrew the filter and just at the very end of the threads, the water gushes out.
LouLawrence
Traveling the US!
Posted: 02/14/22 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
You first need to put the washer in the spin cycle and let it wind up. This will drain the water out and only a small amount of water will trickle out when you remove the filter. Remove the debris and wash it off and reinstall before the spin cycle is completed. Easy Peasy!
rdhetrick
Posted: 02/14/22 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
It's not really a lint filter, it's more of a trap to catch and prevent larger things like coins from going through the pump.
I used to check mine once a year but never found anything. When I checked it, I just had a bath towel ready, it was enough to catch most of the water.
I tried a cookie sheet, but it just spread the water around more!
Rob - Solo Full Timer
2017 Winnebago Travato 59G
Former 2006 Mandalay 40E
larry cad
ohio
Posted: 02/15/22 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Will have to try that. Thanks
larry cad
ohio
Posted: 02/15/22 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Tried both. Either one is a mess. I get lots of lint in mine. Hmmm.
LouLawrence
Traveling the US!
Posted: 02/15/22 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Those are Splendie's instructions for cleaning the trap. It's not a trick I created.
garyemunson
Reno, Nevada
Posted: 02/15/22 07:12am Link  |  Quote  |  Print  |  Notify Moderator
With a bunch of washer owners here, what is the consensus on Splendide washers? Are they well built and reliable? I just got a motorhome with washer prep and have realized there several to pick from (Splendide, Equator, LG). Anyone have comments on them? Thanks!
LouLawrence
Traveling the US!
Posted: 02/15/22 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
The Splendide is great AS LONG AS it is a vented unit. If not, it's completely worthless. The dry cycle takes forever and does a terrible job. We had one in our last coach for 20 years and it was still working when we sold it (we full time so it got LOTS of use).
If you had the room for a stacked washer/dryer (with vented dryer) you will be much happier as you can wash and dry at the same time and usually do larger loads. The Splendide does a great job but has limitations and you must follow the instructions to get the best results.
