philh
Belleville MI
truck stops that have def at the pump
humblerb
houston
Lantley wrote: I quit using the jugs and fill with DEF from a gas style pump at the fuel station.
It's cheaper, but more importanly there is no dripping or spilling.
I was excited when I learned about the possibility of being able to pump. I live in a Houston suburb.
Did a search and the nearest station with DEF at the pumps is about 20 miles from where I live. There are only 3 within a 50 mile radius.
way2roll
Wilmington NC
humblerb wrote: Lantley wrote: I quit using the jugs and fill with DEF from a gas style pump at the fuel station.
I think I have only ever seen one DEF pump at a truck stop. There are none at regular stations anywhere near where I live.
Carl n Susan
Carmichael, CA
campinghut wrote: Ford makes one https://www.amazon.com/Motorcraft-NOZZLE-ASY-PM27N/dp/B008B5WVF8
as an example
This spout is the one to get. It doesn't leak and doesn't require futzing with orientation or such. While it is a Motocraft product it is not limited to just Fords. All trucks use the same filler so it works regardless of your truck brand. Here is a link to the Amazon listing Clicky
![[image]](https://m.media-amazon.com/images/I/51gcPRmmWqL._AC_SL1500_.jpg)
Moderator edit to resize picture to forum recommended limit of 640px maximum width.
last
edited 02/16/22 06:08pm by an administrator/moderator *
View edit history
naturist
Lynchburg, VA
Thanks for the suggestion and the link, @Carl_N_Susan.
It should be noted that the link provided is malformed, however. This should fix it: Fixed clicky
BurbMan
Indianapolis, IN
Carl n Susan wrote: ![[image]](https://m.media-amazon.com/images/I/51gcPRmmWqL._AC_SL1500_.jpg)
OK, so now you've used your fancy nozzle and emptied a box of DEF into the truck. Now what? Wipe that nozzle down with paper towels and put it back in a Ziploc bag that stays, where, in the glove box?
This is like bringing your own custom straw to McDonald's....
It's that big of a deal to hold the box the right way?
way2roll
Wilmington NC
You can't hold it the right way with the hose that comes in the box That's the whole point of the post.
Splashers3
Oakville, MD
My GMC has the DEF intake under the hood.....I don't even mess with the DEF Jug's spout. I take it off, use a flexable funnel (has a long tube). Wife holds funnel and I pour. Works great and she doesn't mind helping out. I do have to stand on a small stool, which we carry in the truck.....we also need to use the stool to reach lock/unlock our hitch.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
jaycocamprs
Ringgold Georgia
Once from the jug, it's been bulk from the pump ever since that first time!
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Cummins12V98
on the road
Jugs are as hard as you make them to be. The Ford nozzle pictured works well but once used be darn sure to rise it out thoroughly.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
