RV.Net Open Roads Forum: Tow Vehicles: Drivetrain slipping?
Search only in Tow Vehicles
 > Drivetrain slipping?
Groover
Pulaski, TN
Posted: 02/17/22 11:11am Link  |  Quote  |  Print  |  Notify Moderator
So yesterday I was headed out to a job pulling my equipment trailer which is pretty heavy and the route includes some hills with up to 7% grades. Going up one of those hills at medium RPM but near full boost the truck bumped like I had hit a small pot hole, but only once and I was going in a straight line so I should have hit with both tires if that was in fact the case. Then it bumped again and a few more times on the way out and the way home. It did this in both 3rd and 4th gears with RPMs ranging from 2500 to 3500rpm. The bump reminded me most of when the chain on my bicycle stretched out and would occasionally slip a tooth on the sprocket. No error messages so far so no clues there. This is a little premature to asking questions but I really don't want to run to failure and end up broken down with a heavy trailer on a 7% grade.
Has anyone had a problem like this before? What did you do to fix it?
My truck is a 2016 F150, 4WD, 3.5 Ecoboost with 6 speed transmission. It could the engine, transmission or transfer case, maybe even the rear axle.
Hank85713
Tucson, Az
Posted: 02/17/22 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Maybe get the vehicle checked for codes at a repair shop or even autozone or similar. Codes may not show but that might be the 1st thing to check imo.
alexleblanc
Moncton NB
Posted: 02/17/22 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
check to make sure your tires haven't rotated on the wheels. I had this happen to me two years ago with a new set of tires and the spin on the bead, felt just like you described.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
Posted: 02/17/22 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
You physically felt it? That's crazy! I've had/seen tires slip on the bead, but never imagined it could be that pronounced.
2017 Heartland Torque T29
Posted: 02/17/22 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Could be transmission related, however it sounds like it could also be a misfire.
I've had a similar condition/symptom on an older Ford (2011) and again with my new silverado.
Feels like you hit a small bump or pothole initially, but with the Ford, it ended up being a couple bad ignition coil packs. The Chebbie had lifter issues.
blofgren
Surrey, B.C.
Posted: 02/17/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, that's a new one for me! What did you end up doing to correct the problem?
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
carringb
Corvallis, OR
Posted: 02/18/22 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Misfire? What's the mileage on the spark-plugs?
2014 ORV really big trailer
2015 Ford Focus ST
theoldwizard1
SE MI
Posted: 02/18/22 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Check the color and smell of the transmission fluid. It should be bright cherry red and not smell. Either of those are bad !
BenK
SF BayArea
Posted: 02/18/22 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with others, think a misfire
As a min, suggest tuneup with new plugs & wires/ignition modules (all of them)
Assuming you were also running 91 octane
Also, have you flushed your coolant yet? 2016 so 6 years and is the coolant is at end of life.
Turbo creates tremendous amounts of heat. More so at full boost. With such a small block/heads, the surface area to reject that big block amount of air/fuel requires very good heat rejection system to get those higher BTU's per square inch surface area out
Ask the others who know more about boosted small engines if dropping down one plug heat range for towing heavy & into high boost a lot would help...but maybe down side would be non-towing, would the plug then foul more easily ?
-Ben Picture of my rig
Posted: 02/18/22 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
But before you freak out, trans fluid "smells" even when new, but it should not smell burnt.
Also, bright cherry red is more an indicator of a recent service and if you have 50k or 100k on trans fluid, (and not all atf is red, but most is) it may be brownish and still functioning properly. (May be time to change it, for sure, but it's not a certainty that it's bad, or causing an issue)
It's just like motor oil or gear oil. It picks up contaminants and those contaminants darken the oil. The red color is also dye, so back to my previous statement. Bright red only tells you it's not that old. It's not an actual sign of transmission health unless you're monitoring it right after a fluid change, which a pan drop and refill which most typically do, only gets about half the fluid.
Some "red" atfs turn color relatively quickly. One of the best fluids on the market looks nasty after not that many miles (Castrol Transynd), but works spectacularly.
In short, if it aint burnt, it aint the problem!
