valhalla360
No paticular place.
If the dollars make sense and it's a layout you like, go for it.
RVs largely use the same appliances and construction methods, so there was never much you were going to gain from manufacturer support.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Rick Jay
Greater Springfield area, MA
Hi,
I'm 99% sure if it was me, I'd go with the Bigfoot. There is only one major thing and a few "nitpicks" that might cause me to reconsider the decision, and even then, I'm not so sure I still wouldn't jump on it, especially if the price was right. The Bigfoot brand & reputation plus the heavier diesel chassis make a pretty tempting combination.
I noticed in the Bigfoot brochure that the Diesel chassis motorhomes were available with either an Onan propane (LPG) powered generator or the diesel powered generator (Quiet Diesel), both rated at 5.5 kW. My preference for an RV generator is that it use the same fuel as the engine of the motorhome. If you use the generator a lot, a propane generator can be a pain as it will require a lot of frequent propane refills. On the other hand, if you don't use the generator much, then it probably won't make much difference.
For us, we tend to run the generator most times we're on the road (either for A/C or heat) to keep the family comfortable. So used in that way, an LPG generator wouldn't be ideal for us.
The other thing I see that might be a bit bothersome is that it looks like you'll lose access to two(?) kitchen drawers when the slide is in? Maybe a cabinet door under the sink, too? Can't tell for sure. And access to the kitchen sink will be a bit encumbered as well. When we travel, we like access to everything in the kitchen without putting out the slide.
Both rigs have split baths, and while not my preference, IF I had one in my motorhome, I'd prefer a layout similar to your current rig, which I believe has the sink and the john on the same side of the aisle, and the shower opposite. I think the Bigfoot has the john and the shower together.
And I'm REALLY nitpicking now, but personally I'd prefer a dinette (which looked to be an option on the Bigfoot) to the folding table & chairs shown on the brochure.
But if that rig has a Quiet Diesel model generator, I'm pretty sure I could live with the other possible issues.
Good Luck and be sure to let us know what you decided! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
~Rick
last
edited 02/19/22 08:30am by Rick Jay *
View edit history
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (25-Angel since 2008), 1 girl (20), 2 boys (21 & 18).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
bobndot
Check the size when changing rvs. Height might be taller, I know someone who smacked his new rv into a low driveway tree branch that he cleared with his previous rv.
Whenever I change trucks I look into the turning radius and ground clearance at the rear. I have a tight swing and steep driveway apron to navigate.
I can't back into my driveway with my current rv. The rear overhang drags on the apron and sidewalk. I can only pull head-in and the rear overhang just clears dragging its hitch welded 'safety tabs' in the street.
clotus
ca
Thanks for all the input. I am going to be taking a closer look over the entire RV to ensure there aren't any issues that I am not aware of, but I think I am going to go for it. I will post some pics if/when......
Current: 2017 Winnebago 31K
(Sold): 5th wheel: 2015 Heartland Sundance XLT 245
ronfisherman
SE Michigan
When I looked at a Bigfoot Super C. One thing that caught my attention was fuel tank size. It was smaller than the 80 gallon tank in most Chevy Super C’s. One other item was access to cab from living area. All other manufacturers has a cutout to give access to cab. Beyond those items I liked the layout.
Depending on when this 2007 was built. It may have the LBZ engine. After 2007.5 they had LMM with DPF with 6 speed transmission. My preference would be the LBZ. It can get a program update for 6 speed.
Hope this one is what you want in a Super C.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
LBZ are already 6 speed in 06-07 in the light duty trucks. Did the med duty keep the 5 speed longer?
2017 Heartland Torque T29
ronfisherman
SE Michigan
Grit dog wrote: LBZ are already 6 speed in 06-07 in the light duty trucks. Did the med duty keep the 5 speed longer?
2006 to 2007.5 Medium Duty C 45-5500 had a 6 speed transmission. But no program for 6th gear. GM never labeled the LBZ in MD trucks . They labeled it LLY. But it had LBZ updates.
CharlesinGA
South of Atlanta, Georgia
I am a member of the Bigfoot Owners Club Intl. and on the discussion forum there are several owners of the 4000 series. Most speak well of them, but they are not without their issues.
If the one you are planning on getting has been well cared for and kept under cover or shelter, it will be a real nice rig.
I would think you could sell your 2017 model and if a clean rig, make almost what you paid for it. Just be a wary seller and double check everything. When I sold my MH in 2019 I went behind the buyer and checked with the credit union they were borrowing part of the money with, to confirm it was a legit deal. I contacted them thru the email address I got off their web site and not via the one the CU employee handling it was using. I gave all pertinent info and simply asked for a yea or nay that the loan was actually being handled and was legit. They said yes. The buyer said he was going to give me a Wells Fargo cashiers check for a part of the price, so when they arrived (flew in on airline) i picked them up in the motorhome and we went to Wells Fargo. Oddly WF could not easily confirm the checks, they needed to talk to the issuing location, which would not open for 3 hrs. However the manager looked at the buyers accounts and saw that that exact amount had been moved out of the account. I also had done a bunch of research on the buyer, where they lived, I checked the property tax records for the address to confirm the ownership, and several other things.
There are some pretty good scams going right now. The very best thing you could do would be to walk into the sellers bank or credit union and be handed a check by the teller for the proper amount.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
bobndot
Charles, you could star in your own detective Netflix series.
kwplot34
home
I have a Super C on a 2020 F550 chassis 6.7L diesel, finding a shop to do maintenance on it is not an issue. Having owned several motor homes on the E chassis, you will enjoy driving this one much better. I will never go back to a gasser.
