RV.Net Open Roads Forum: Truck Campers: CB Antennas?
 > CB Antennas?
OkieGene
oklahoma city
Posted: 02/24/22 02:25am Link  |  Quote  |  Print  |  Notify Moderator
The shorter the antenna, the more lousy it the reception/transmission becomes.
You have to do what you have to do, but that's a lousy idea, the shorter antenna.
You need to get at least 1/4 to 1/2 wavelength, and decent coax and connectors.
Most CB coax is junk and the connectors are too.
Best wishes to you.
Supercharged111
Colorado Springs, CO
Posted: 02/24/22 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Best wishes to you.
A fender mount can't handle a 5 footer?
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
JoeChiOhki
Sauvie Island, OR
Posted: 02/24/22 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Supercharged111 wrote:
I am liking the fender mount idea. This site has a bunch, but not seeing one that specifies my year.
https://www.wearecb.com/hood-mount/
I'm sure a number of them would work fine. I feel if I could find someone locally with a selection that that would be the best solution.
Check your local CB dealer or truck stop. I got my original hood gap mount bracket from a shop in a nearby city. I'm on my third Firestik (Damaged the last one like a moron in a drive thru) and the original wore out after several years.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
BradW
Mayor of Flat Rock
Posted: 02/25/22 02:36am Link  |  Quote  |  Print  |  Notify Moderator
I have a fender gap mount on our jeep jk. I would not trust it to handle a 5' antenna.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
JoeChiOhki
Sauvie Island, OR
Posted: 02/25/22 03:06am Link  |  Quote  |  Print  |  Notify Moderator
What's the anchor points like on yours? Mine has five screws that anchor it into the body and its been successfully holding the 5' firestiks without a spring for sixteen years, including having a dolt like me smacking the antenna into tree branches and a low hanging drive thru.
If your hood area is aluminum or plastic, then yeah, that makes total sense, but if its half way decent sheet metal one like that should stay put.
BradW
Mayor of Flat Rock
Posted: 02/25/22 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
https://youtu.be/H_s4kA2LEh8
Similar to this mount. I added two additional screws and a spring.
* This post was edited 02/25/22 09:17pm by BradW *
covered wagon
Posted: 02/26/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I removed mine after hearing the amount of swearing and very rude language. So glad it's gone, Just like avoiding a place where it more important for some individuals to throw others under the bus and click about it.
BradW
Mayor of Flat Rock
Posted: 02/26/22 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I generally use our cb when we are traveling with others who have cb radios. I only switch to 19 when there is a wreck/traffic back up or I'm just bored.
Swearing doesn't bother me on 19. What does piss me off is the racist insults aimed at people out working hard just trying to earn a living.
JoeChiOhki
Sauvie Island, OR
Posted: 02/28/22 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Mk, yeah I can see why you might not trust it. Its thinner than the mount I have and would likely be more prone to bending.
burningman
Seattle, WA USA
Posted: 03/01/22 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
BradW wrote:
On our old lance I mounted two 2' firestik antennas on the top of the ladder.. Since they "saw" each other, they used each other as a ground plane. That setup worked very well.
A groundplane is an entirely different thing. It’s effect is to lower the radiation pattern from mostly skyward to more line of sight.
Two antennas near each other affect the radiation pattern differently, they make it more directional. They really need to be about 9 feet apart, a quarter wavelength.
The reason you saw that on trucks in the CB heyday with twin antennas on the mirrors, which are about 8 feet apart, is they make the radiation pattern like a figure-8 as viewed from above. They’re directional to the front and rear, and much less to the sides.
The idea was to concentrate the signal up and down the highway and minimize interference from the sides.
Your ladder was acting as the groundplane.
The reason they works well was how high up they were. You’d probably do better with a single one.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
 > CB Antennas?
