RV.Net Open Roads Forum: Class A Motorhomes: Any Allison transmission general info ?
 > Any Allison transmission general info ?
LandYacht35diesel
Florida STAYcation
Posted: 02/20/22 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
.. absolutely no problems here .. and I sure don’t want any. Any tips and preventive maintenance issues ?
MountainAir05
New Mexico
Posted: 02/20/22 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Filters and fluid change when due.
wolfe10
Posted: 02/20/22 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
For advice, PLEASE tell us what Allison transmission you have or better yet, fill out your signature so we know what you have (year, coach, engine, trans info really help with accurate answers).
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
LandYacht35diesel
Florida STAYcation
Posted: 02/20/22 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
97 airstream land yacht .. 5.9 Cummins 12 valve
wolfe10
Posted: 02/20/22 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Allison 6 speed 3000 series electronic transmission or Mechanical 4 speed.
Both were used with the Cummins B engine, as were some 5 speed 1000 and 2000 series.
LandYacht35diesel
Florida STAYcation
Posted: 02/20/22 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
It’s a 6 speed .. shifts great … it’s no race transmission though !! .. is 5th and 6th overdrive ? I assume there is no lockup converter … yes ?
wolfe10
Posted: 02/20/22 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
If 6 speed, 3000 series transmission (like MD3060) 4th is direct, 5th and 6th are OD's. There will be a plate on the driver's side of the transmission with model and serial number-- good to have when ordering parts/filters as there are both shallow and deep pans.
Torque converter is locked in "high 2nd" and all higher gears. The lock up in second is at higher engine speed and feels like a mini-shift.
Servicing is pretty straightforward. Get the filter kit from an Allison dealer. It has filters, gaskets and instructions. Not a difficult job.
Then get a 5 gallon pail from the Allison dealer of Transynd 668 (the newest fluid that replaces earlier fluids).
* This post was edited 02/20/22 03:12pm by wolfe10 *
gbopp
The Keystone State
Posted: 02/20/22 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't know when the transmission was last serviced, do it now.
Then you will have a base line for future maintenance.
It's cheap insurance.
Ava
Vancouver Island. BC Canada
Posted: 02/21/22 10:08am Link  |  Quote  |  Print  |  Notify Moderator
My 1994 six speed Allison still runs without any issues. When I first got this rig, I had the trans fluid tested and then replaced the Transynd and filters. The test gives you a good indication of the condition of the trans. I have changed it once more since then.
Blaster Man
Posted: 02/21/22 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Get the fluid tested annually....JG Lubrication. I've been using them for 11 years, get a detailed report back within a week:
http://www.jglubricantservices.com/
2014 American Eagle
