RV.Net Open Roads Forum: Fifth-Wheels: B.R. AC not blowing cold air
 > B.R. AC not blowing cold air
M.R.E.
MI, usa
Posted: 02/21/22 08:35am Link  |  Quote  |  Print  |  Notify Moderator
My Columbus has two AC's. Main is fine but bedroom ac doesn't blow cold air. Any suggestions for what can be wrong ?
toolmaker
sayoung
Tx
Posted: 02/21/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Refrigerant leak, locked compressor, bad run capacitor, bad thermostat, open overload just for starters.
WILDEBILL308
FORT WORTH , TEXAS
Posted: 02/21/22 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the thermostat to make shure it is set to the right "mode"?
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
TXiceman
Full Time RVer
Posted: 02/21/22 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Brand and model of A/C and thermostat will help us that do not own that brand of trailer.
Next, are you getting power to the bedroom unit, is compressor running, is blower running, is thermostat set correctly? Lots of info needed to help you.
Ken
Amateur Radio Operator.
M.R.E.
MI, usa
Posted: 02/21/22 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Dometic ACs and Dometic control center 2 thermostat. They both start and shut off when temperature is met. Must need to recharge it. Don't know if you can recharge RV ACs?
TXiceman
Full Time RVer
Posted: 02/21/22 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
MRE, the RV units are sealed and do not have charging connections. They can be installed, but to be done properly, it is not cheap. A unit losing its charge is not a common failure mode. You need to do further diagnostics before you go down that path.
How old are the units?
Ken
M.R.E.
MI, usa
Posted: 02/22/22 07:05am Link  |  Quote  |  Print  |  Notify Moderator
The trailer is a '15 Columbus. Bedroom ac has never worked right.
