C130rocks
New Mexico
I'm new to this site, so forgive me if I'm asking a question that's has been answered. I'm in the process of getting a Class C and when I take them for a test drive the rattles inside were a little loud. Some I can figure out, but the question is this a normal issue. I asked the salesman and he stated that the road noise was common. Thanks in advance for information.
NamMedevac 70
Reno
One of reason I decided to not purchase a class C. I read many years ago of numerous reports of loud rattling on moving class Cs from many owners and they were unable to solve the issue so I went with a TT and left the noise behind me. Good luck. Cheers
Tyler0215
Iowa
IT'S A TRUCK! Trucks ride rough and shake things loose. If you watch a video of how RV's are built you will wonder how they stay together at all.
bukhrn
Lanexa, Va
Only loud rattles I hear are the pots and pans, and the Cast iron pans carried in the oven.
2007 Forester 2941DS
2014 Ford Focus
way2roll
Wilmington NC
You didn't say what year and model you were looking at. Things are relative, a cheaper built unit will ride rougher than a Super C on a diesel chassis. The same way a 87 Yugo will ride differently than a 2020 Mercedes. As a general rule however, most gas MH's either A or C will make a good deal of noise going down the road. Some rattles can be chased down and fixed (I was obsessed over this on our previous 2 class A gassers). Some noises would be a greater concern than others, depending on what is causing the noise. LOTS of contributing factors, tires, PSI, alignment, weight distribution, things not stowed properly - a million reasons. You'll need to drive quite a few to determine what's normal and acceptable vs what you can tolerate. If you want the best ride for an RV, look at a diesel pusher.
lancewgurel
Spokane Valley WA
I find it quieter if I don't wear my hearing aids.
IAMICHABOD
Sunny So Cal
As stated they are a truck and they will ride harshly and rattle especially when they are empty.When loaded with your camping gear and everything else the chassis will be loaded and smooth out the ride and lessen the noise.
In my search for a Class C all I drove were on a Ford Chassis and noise from the engine and rough ride seemed common,then I drove one on a Chevy Chassis and the noise and harshness of the ride was remarkably different.Soother,quieter and easier to drive.
So maybe try to find one on a Chevy Chassis and give it try
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
lancewgurel wrote: I find it quieter if I don't wear my hearing aids.
Best answer yet!
2017 Heartland Torque T29
lancewgurel
Spokane Valley WA
I will add a more serious reply and that's to see if you are overinflating your tires. I reduced my tire pressure and the ride improved considerably.
Near Mammoth, California
“I find it quieter if I don't wear my hearing aids.”
I find it quieter not to have hearing aids!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
