RV.Net Open Roads Forum: General RVing Issues: Doing without propane
 > Doing without propane
Page of 6
msmith1.wa
Tacoma, WA
Posted: 02/27/22 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't see any one suggest an extend a stay, or stay longer kit.
Stay Longer
It will allow you to connect a propane bottle to the motorhome system.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
JRscooby
Indepmo
Posted: 02/27/22 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Stay Longer
way2roll wrote:
Maybe I am missing something but this seems like it's being made overly complicated. If the existing tank is bad, and if it really takes forever to get a replacement built in, a simple device like an "extend a stay" hooked to an LP tank you can get at any grocery store will work. I am not sure what RV you have but I see LP tanks of varying sizes everywhere. Are you saying you can't find a single one to replace the existing tank? Even if the mounting hardware had to be fabricated by a welding shop, it doesn't seem that hard or expensive,
And even before that part of one of my posts
Back when Dad was full time, he had a valve system (Extend-a-Stay?) so he could put a larger tank outside, have a truck come by and fill it. He kept the onboard tanks hooked up, but turned off. (Get up, turn on tank, light furnace not good. Wake up, discover totally out even worse)
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 02/28/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I have converted my truck camper to all-electric, but here's my caveat: we enjoy staying in campgrounds and state parks. If we boondock, it's only in temperate weather.
For heat (even when we had a motorhome; and then a 5th wheel) I use a Pelonis digital electric heater. It has a true thermostat, so we can set the temp to 72 degrees and it will keep it there; plus it has tip-over protection that turns it off immediately if it gets bumped. The added bonus: no condensation gets formed. It's dry heat.
ajriding
st clair
Posted: 02/28/22 08:27am Link  |  Quote  |  Print  |  Notify Moderator
No, solar panels will not compromise your roof, not any more than sitting on a chair will compromise the chair, even less in this example.
You will need a hole or entrance through the roof, so that is a compromise, but you already have a lot of holes for vents. The Fridge vent is a hole you can use if needed too.
The weight of a panel is nothing on a roof.
Did I read someone said a new tank is $1,000? No. Shop around. You could even find an RV in a junk yard with a perfectly good propane tank if needed, and pick it up for dollars.
If money is an issue then plumb in the bbq tank and use them, they are cheap and easy to come by. your brother-in-law will give you one just for feeling sorry for you.
Brownleaf
Durham
Posted: 02/28/22 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for tip on Pelonis.20 How does a solar panel mount to the roof?
pianotuna
Regina, SK, Canada
Posted: 02/28/22 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
What is the roof made from? Various types require different fastening. My roof is some sort of membrane, so screws were needed.
I beefed up the panels with aluminum angle riveted to the longest sides.I recommend that to all who wish to attach the panels permanently.
Of course, all penetrations were treated with dicor.
Other types of roofing may be able to use VHB tape.
For electric heating I use oil filled radiators.
I carry one heater with a fan, and one radiant heater (useful for thawing frozen compartment doors and the like.
I can heat 100% electrically at -37 c (-34 f). It does take LOTS of watts to do so.
Regards, Don
valhalla360
No paticular place.
Posted: 03/01/22 12:25am Link  |  Quote  |  Print  |  Notify Moderator
Propane furnace is dry heat also. The combustion does not occur inside the living space. It's completely vented via the exhaust pipe.
Though if on shore power, we also supplement with a small electric space heater as they usually don't meter the power and it extends the duration of a tank of propane.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Posted: 03/01/22 12:28am Link  |  Quote  |  Print  |  Notify Moderator
I hear people say this but the most common end of life issue for RVs is roof leaks causing rot.
In theory if you are religious about it, it can be OK but it adds more holes and more places you can miss a leak. Back in real life, yes, it increases the chances of leaks.
Honestly, I would love if they switched to mini-split air/con units and wall mount vents, so you could largely eliminate roof penetrations. That would eliminate a lot of roof leaks.
fullmoonoversalem
Alaska
Posted: 03/02/22 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Friends of ours have a small C and just converted the heat over to diesel heat. They also converted the propane generator to diesel. Expensive, but they are propane free.
2017 Coachmen Galleria
Brownleaf
Durham
Posted: 03/02/22 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Im going to attempt to refurbish the tank and in the process will discover how deep that rust is. First I am going to have my Onan taken it out as it is not cost effective to repair it. Doug
Page of 6
