NamMedevac 70
Reno
I was fortunate in my 15 years of towing my quality-built R-Vision Trail Cruiser BH I never experienced any serious issues with the unit that included harsh towing conditions in the mountains and coastal areas and some long term outdoor storage in extreme hot sun of Texas and Nevada. Those were the days.
Veebyes
Thanks for my laugh of the day. Had to read this one.
We are rolling around the country with a 2007 5er which has had well over 1800 nights spent in it & some 220,000 truck miles. With age & use stuff goes wrong. It has been in storage, & not even seen, since last October but the spring refit list is well underway where we actually do go into a boatyard to do the work.
The Amazon order for known issues gets placed in a week or so. I am figuring 3-4 days of boatyard work. Any longer & they start threatening to launch me with the travel lift.
2007 Alpenlite 34RLR
jdc1
Rescue, Ca
memtb wrote: jdc 1, We should write a book together! That sounds like some of our trips over the last 30 or so years! The bright side....it keeps life interesting! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
memtb
That it does. I've repaired everything, even stuff I didn't know was screwed up until I got home. Boy, I'm glad I can do this stuff, or I might be living in this trailer (5th wheel) because I would be broke if I had to pay RV repairman prices. Yeah. I get sore getting up and down, crawling under and over, contorting my body like a hula dancer....but.....That soreness goes away in a few days,
jdc1
Rescue, Ca
Veebyes wrote: Thanks for my laugh of the day. Had to read this one.
Just look at all the money you save keeping that trailer and old boat!
Veebyes
jdc1 wrote: Veebyes wrote: Thanks for my laugh of the day. Had to read this one.
Yes, that 32' diesel powered boat would probably be well over $5K worth of maintenance each year BEFORE turning the key for the first time.
The truck & 5er are well under that. You get to a point where the depreciation rate curve flattens out considerably but things needing attention increase & can get expensive such as new stove this year.
memtb
Wyoming
jdc1 wrote: memtb wrote: jdc 1, We should write a book together! That sounds like some of our trips over the last 30 or so years! The bright side....it keeps life interesting! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
memtb
Some of my more interesting repairs involve weather extremes! Replacing an igniter rod on the refrigerator in blowing snow with temps in the teens on a 3 week boondocking trip, replacing a complete hub/brake backing plate assembly and “dressing” the slightly damaged axle stub with a file in single digit temps (though it was sunny) in a rv park in Evanston, Wy., to replacing a broken spring pack, in an asphalt parking lot..... August in Mesa Arizona. There’s plenty more ......but, you get the picture! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Veebyes
Got one that would have surely cost us thousands if it was taken to a dealer. Changing the black tank gate valve.
Our Alpenlite has a Waste Master electric gate valve system. Great when it works, push a button, not so much when it does not.
Changing the valve, in an extremely awkward inaccessible location, involves getting the tank empty as possible at the dump then going somewhere on a slope, or creating a list with boards to make what does not drain go to the low side away from the valve.
You then have to get under the trailer, with your face right below the valve that you have to remove.
I will stop the story there. It only gets worse.
jdc1
Rescue, Ca
Veebyes wrote: Got one that would have surely cost us thousands if it was taken to a dealer. Changing the black tank gate valve.
I am getting a vivid picture.....LOL.
