RV.Net Open Roads Forum: Tow Vehicles: Joined the B&W Hitch Club
Search only in Tow Vehicles
 > Joined the B&W Hitch Club
Page of 6
MFL
Midwest
Posted: 03/03/22 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Another sometimes overlooked option, when considering anything to do with B&W installation, is your phone. B&W does install their hitches in all type vehicles, and can give first hand info, regarding any complication that could arise. If the person answering the phone cannot answer your question, they will quickly hook you up with the right person.
Jerry
Learjet
Louisiana
Posted: 03/03/22 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
good point on the widebody ....I got one coming in a few weeks....will have to recheck my clearance with my Jayco Pinnacle.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
garyp4951
TN
Posted: 03/03/22 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, hard to beat the old 8' bed.
My driveway grade goes down hill from the street and thats what got it.
blofgren
Surrey, B.C.
Posted: 03/03/22 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
OP...You should be in great shape at 39.5"s of tow position clearance. It does make a difference having a wide body FW, and I'm sure you know that. The front cap shape also makes a difference, mine has what manufacturer labeled EZ-Turn for standard bed trucks.
Good you got the slider. The time may come when you will be more comfortable using it. I'm sure you will check for pinbox/tailgate/bedrail clearance when trailer is home, and first hookup.
FW on your sig page looks to be a great, quality built trailer. I looked it up.[emoticon]
Jerry
Yes, I will definitely need to experiment when I get the trailer home and I will report back. I'm now wondering if clearance to the tailgate will be an issue; that will be interesting to see.
Yes, the fiver is definitely a great trailer; they were somewhat overbuilt with respect to frame and running gear with 8k lbs axles. It has a full winter package good to -30C that is also great in the heat. They were made in Oliver, BC, but unfortunately didn't survive the 2008/2009 recession. We are on our second one, which replaced a 30' single slide unit that we bought new.
With respect to the long bed, that was a no go for me because the truck would have been too long to fit in my garage. I was willing to sacrifice a bit of bed space in order to have the truck inside.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
blofgren
Surrey, B.C.
Posted: 03/03/22 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
^ Good point Gary! That is where bed length can make a difference. My Ford standard bed is 6' 9"s.
With OP's arms in full rear position, and like you 6' 4" bed length, an adjustment may be needed, for hitch to fully slide. Again, pin box design, bed rail clearance, can differ. Pin box support can be trimmed, or in your case, a FW gate works for you.
Jerry
Thinking about this a bit further, my fiver has an extended Morryde pin box, so yes clearance to the tailgate may be an issue. Then again, maybe with the arms in the rear position, the slider won't be required. I'll need to check this out carefully when I get the fiver home.
ACZL
UPstate,NY
Posted: 03/05/22 06:23am Link  |  Quote  |  Print  |  Notify Moderator
I joined the B&W club back in '17 with their Patriot non slider model and won't look back. Best thing I did. At the time, had a SB F350 which got traded for a DRW in '18 but same hitch as the '18 didn't have the puck system option (off the lot buy). I can simply just reverse the whole top half to move the king pin back/gain more room between cab window/5er as well as front compartment/bumper of truck. Granted the DRW is a LB, still the B&W works flawlessly. And yes, the Pres of the B&W club was consulted 1st! LOL
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Cummins12V98
on the road
Posted: 03/05/22 09:04am Link  |  Quote  |  Print  |  Notify Moderator
"And yes, the Pres of the B&W club was consulted 1st! LOL"
I think it's high time your "HeavyWeight" standing is upgraded!!! [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 03/05/22 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Because I have a B&W hitch sitting in our garage am I a fan club member also???
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
MFL
Midwest
Posted: 03/05/22 11:55am Link  |  Quote  |  Print  |  Notify Moderator
^ Yes, even if you owned a B&W and sold it, the membership and memorable experience is forever!
Jerry
Cummins12V98
on the road
Posted: 03/05/22 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
For sure!!!
You need to put that on Craigs List in June.
Page of 6
