RV.Net Open Roads Forum: Fifth-Wheels: New Outside Stairs
 > New Outside Stairs
Page of 8
garyp4951
TN
Posted: 03/02/22 07:33am Link  |  Print  |  Notify Moderator
I love my Solid Step especially the 13" top step that is like a landing when stepping down and rock solid.
It takes maybe 10 seconds to sweep them before closing up.
frankwp
Calgary, AB, Canada
Posted: 03/02/22 08:23am Link  |  Print  |  Notify Moderator
The solid steps are not for me. There are too many places where I wouldn't be able to get in, like at the storage yard or at a gas station. Virtually every gas stop someone needs to get in for some reason. We can just climb in without pulling the steps out. Tough to do with solid steps. And there's the whole clean up thing. I know it isn't a huge deal, but it's just one more thing to deal with. I have enough things to deal with already.
I do plan on getting the Torklift steps though. My wife has a funky hip & I can get the Torklift with an additional step.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
TXiceman
Full Time RVer
Posted: 03/02/22 08:42am Link  |  Print  |  Notify Moderator
Our daughter has Solid Step stairs on her RV and they are a pain in the rear. Where they store the unit, if someone is parked next to them, they cannot get the stairs down to get in the trailer. They have to hook up to the truck and pull the rig forward. With the old rig and the regular folding steps, they cold fold them out and get into the rig.
For me, they are a deal killer as if there is dirt on them, it is dumped inside the RV.
Ken
Amateur Radio Operator.
goducks10
There
Posted: 03/02/22 08:46am Link  |  Print  |  Notify Moderator
I installed Solid Steps on my TT. I love em. However I also have two entry doors. I would never put them on a single door 5th wheel. %th wheels sit high off the ground like our TT does. That means you need a minimum of 3 steps and probably 4. That makes the arc to drop them down longer and they will stick out further. The other drawback is pulling off the side of the road and wanting to use the head or grab a bite. If the 5er's not close to level then you have to fiddle with the steps so they deploy right.
Not so with my two door TT. We just use the front entry door when on uneven ground or tight situations.
The other drawback is you once you're backed into your spot you can't get into the 5er until it's level and set up or you risk tweaking the steps.
Cummins12V98
on the road
Posted: 03/02/22 09:58am Link  |  Print  |  Notify Moderator
Forget the solid steps that have several issues. Replace your flimsy POS steps with a set of these. VERY solid with only 1/2" deflection with me @ 200# standing on the bottom step. I have had these for 4 years and they still look new and we are full-time. NO WAY you will slip on these!
rvautoparts.com
1424 ALUM BOXED Elkhart Tool and Die Entry Step 4 Manual Folding Steps
Your Price: $322.65
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Lantley
Ellicott City, Maryland
Posted: 03/02/22 03:36pm Link  |  Print  |  Notify Moderator
In all your post you are not one to go cheap.
Get a set of real Torxlift glow steps. They will look the same as those fake torxlift's you posted. But they will actually be totally stable because they will be supported by the ground.
You know better that to bargain shop![emoticon]
* This post was edited 03/02/22 05:13pm by an administrator/moderator *
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Gray Fox
Swansea Ma. USA
Posted: 03/02/22 07:02pm Link  |  Print  |  Notify Moderator
Thanks for all your answers about the folding steps. I may look into
the Elkhart 4 Manual folding steps they look good..
Gray Fox
2014 F350 4x4 Diesel Lariat
2009 HitchHiker-LS 34.5 RLTG
Always keep moving so you don't seize up.
Cummins12V98
on the road
Posted: 03/02/22 07:18pm Link  |  Print  |  Notify Moderator
The ones that came on our DRV were steel sand same quality and sturdiness. Our steps encountered a concrete light pole base(OOPS). So I was happy to find these with the aluminum and anti skid that just made them better!
Cummins12V98
on the road
Posted: 03/02/22 07:20pm Link  |  Print  |  Notify Moderator
Not sure who you are talking to???
I was asked by TorkLift to try out a set and was told I could keep them if I would give my honest opinion.. I declined but IMHO they are nice quality but I love what I have.
valhalla360
No paticular place.
Posted: 03/02/22 07:34pm Link  |  Print  |  Notify Moderator
fj12ryder wrote:
They have to be adjusted for almost every time they are deployed.
Back when we had the 4 step cantilever style, we had to adjust every time because I would put a couple aluminum jack stands under the last step because they flexed so much otherwise.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Page of 8
