RV.Net Open Roads Forum: Tech Issues: What System panel do i have?
 > What System panel do i have?
Rycher
lockhart
Posted: 03/03/22 12:27am Link  |  Quote  |  Print  |  Notify Moderator
I cant find any info on this thing. anyone seen this before and know the manufacturer?
larry cad
ohio
Posted: 03/03/22 02:40am Link  |  Quote  |  Print  |  Notify Moderator
I would take out those two screws, and remove the device so I could look at what is on the back. Probably a manufacturer name and model number.
Our Travel Blog
Dutch_12078
Winters south, summers north
Posted: 03/03/22 06:38am Link  |  Quote  |  Print  |  Notify Moderator
KIB has made panels similar to that one for many years. If your tanks have the common 4 wire "studs through the tank wall" sensor setup, then it's likely KIB. Here's a link to their current version of that panel:
KIB® - M21 Tank Monitor System Panel
Dutch
2001 GBM Landau 34' Class A
Dusty R
Charlotte Michigan 48813
Posted: 03/03/22 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Not what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
3 tons
NV.
Posted: 03/03/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Actually, ‘SeeLevel’ by Garnet.
Dusty R
Posted: 03/03/22 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Good catch, thanks.
mobeewan
Hampton, Va
Posted: 03/03/22 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Might be able to take the screws out and pull it out far enough to see if there is amfg and moder number. Worse case might need a flashlight and or mirror.
Rycher
lockhart
Posted: 03/05/22 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
just fyi for all.. i was able to pull it out far enough to see its a geckotech model ecp. very similar to the KIB's on the market..
