RV.Net Open Roads Forum: Travel Trailers: 6 VOLT BATTERIES, MINIMUM VOLTAGE
 > 6 VOLT BATTERIES, MINIMUM VOLTAGE
ajriding
st clair
Posted: 03/04/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
My batteries will usually be below 12 by morning. I used to camp / boondock a lot when I used it for work, but use much less now. Batteries are maybe 8 years old, and still going strong. They are GC batts.
The answer is not absolute. There is a balance between using the batteries for your needs, conserving voltage to "save" the batteries, and the fact that you likely will not use them enough to cycle through the life supply of what they can do in a reasonable amount of years.
Most RVers will need 20 years to cycle through half of the available cycles a battery can do. I think 20 years the battery will die of other causes than life cycles first. You have to know what your needs are. A full-time RVer who uses a lot of battery power will need to be judicious with his power use, where a weekender can ignore largely what he does.
jdc1
Rescue, Ca
Posted: 03/04/22 08:45am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
This might be helpful to somebody.
It was taken from The 12 volt side of life.
This should be printed on every deep cycle battery.
Owens River area
Posted: 03/04/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
"Right now I'm testing how long they will run the furnace in anticipation of several days boondocking."
Experiment away but if you are not refilling your wet batteries daily their life will be shortened. 11.75 volts resting is about 30%...another battery life shortening event.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
TBammer
Mid-Michigan
Posted: 03/04/22 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
What type of test is needed to check if the battery might have been abused in the past? Asking for friend.
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
ktmrfs
Portland, Oregon
Posted: 03/04/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
My battery testing method I use at the start of each year is to use a GOOD charger to equalize the batteries making sure they are fully charged and each cell equalized. Note.... The typical WFCO charger commonly used in trailers will NOT fully charge, let alone equalize the battery. A Progressive dyanamics or Iota can.
Then for the specific battery, go to the mfg web site and see what they indicate for battery specific gravity (SG) and at what temperture.
Then with a calibrated hygrometer that has a temp compensation chart (not the cheapie at the local parts store) Friese (sp?) makes an excellent one. measure EACH cells SG and write it down. Then compare that to what the mfg says the NEW SG should be. If each cell is about the same reading and close to the spec'd SG, your good to go with a battery near tip top shape.
If one or more cells is much lower than the others try another equalizing charge, if it doesn't change, you've got weak cells and the battery is on it's way out.
if all cells are low, again your nearing battery end of life.
Note: I didn't mention doing a load test. On GC2 batteries load test is of very marginal use. GC2 are NOT designed for high loads like a starting battery so (1) if load testing a GC2 you don't want to use the common X times AH as the load, you'll be WAY over a valid test and (2) If the mfg does give a current load for a load test you can try it if you can find a adjustable load tester.
I've never tried to load test a 12V marine/rv/starting battery so I have no clue as to how valid a load test is on such a battery.
And as a check with the battery AH rating for 20 or 24hours, and if you have a load that would match that AH rating (AH/20) you could run a load on it and check resting voltage at 6hours and 12 hours to see how close you are to 75% and 50% SOC. If at 6 hours your below the 75% SOC, don't go a full 12 hours, go say 8 measure again, if not at 50% continue. in the end you should have an idea of battery AH capacity vs. rated and an idea of battery condition.
2011 Keystone Outback 295RE
Boon Docker
Posted: 03/04/22 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
This info will help your friend.
ktmrfs
Portland, Oregon
Posted: 03/04/22 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
good info for 12V starting batteries and maybe marine/rv but not really valid for a GC2 battery. One, GC2 seldom if every have a CCA rating to use as a benchmark, Next They have a few very thick plates to much more internal resistance than a starting or marine battery. End result is if you try to load them to the typical load test, results in almost all cases will be "fail" even on brand new GC2. Unless the GC2 mfg gives a recomended load test current.
My experience is that loading a GC2 to between 1/2 and rated rated AH (60-100A on a typical GC2) gives some valid info,
Boon Docker
Posted: 03/04/22 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see anywhere that he mentioned a GC2.
ktmrfs
Portland, Oregon
Posted: 03/04/22 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
nope he doesn't mention ANY info on battery type, so may as well give him info relevant enough to the two common battery types, 6V GC or 12V marine.
and the OP started the discussion stating he is using GC2 batteries.
time2roll
Posted: 03/04/22 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would start with a hydrometer.
675w Solar pictures back up
