enblethen
Moses Lake, WA
My mind keeps coming back to inverter, if equipped. Feed through function.
Do you have an inverter? If yes, turn it off, then restart.
Does receptacle work on battery power through the inverter?
Try turning off all circuit breakers in the rig. Apply slight pressure toward off. Turn on main breaker, then branch breakers one at a time.
Does your rig have a detachable cord? Check connections in cord body.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
theoldwizard1
SE MI
Allworth wrote: GFI needs a hard ground.
Not true !
GFI works by measuring the current flowing in and the current flowing out. It trips if they are not equal.
GFI can be used in old houses with no grounds (requires that the outlet be labeled as not grounded).
BB_TX
McKinney, Texas
theoldwizard1 wrote: Allworth wrote: GFI needs a hard ground.
Not true !
This is correct. However, there must be some ground path back to the power source for the GFCI to be able to have a discrepancy between the current in the hot pin vs the current in the neutral pin. The GFCI works on the principle that that there is some current "leaking" out of the circuit. For there to be any current flowing outside the circuit in question, there must be some path for that current to flow back to the source. Electricity requires a closed path to flow. If that path does not exist, then current can not "leak" out of the circuit. In old ungrounded homes, that ground could be plumbing at the various sources of water.
JRscooby
Indepmo
BB_TX wrote: theoldwizard1 wrote: Allworth wrote: GFI needs a hard ground.
Not true !
That "leak" the GFI is detecting is what is running up your arm on it's way to ground. For decades, normal house wiring was only 2 conductors to outlet or lamp. There was no path to the water pipe for most uses.
ScottG
Bothell Wa.
JRscooby wrote: BB_TX wrote: theoldwizard1 wrote: Allworth wrote: GFI needs a hard ground.
Not true !
A GFCI does not have to have a path to ground to work. It detects current flowing outside of the normal hot-neutral circuit as already described and assumes the leakage is through something else bad but it doesn't actually have to determine where it's going.
A warning on replacing GFCI's! A few years ago they changed the connection points so the old "Line In" and the "Out" were reversed on new GFCI's. If you don't look closely at what you're doing and hook the new one up exactly the same as the old parts, you can put the new one (or a whole kitchen full..) in backwards and it will be dead (but not damaged). Don't ask me how I learned this lesson..
BB_TX
McKinney, Texas
Not true !
Electric current requires a closed circuit, meaning a path back to the power source. Basic fundamental of electricity. In the case of utility power it means a path from hot back to earth ground or to neutral. It can’t just leak out to anywhere it wants. “Running up your arm” will only happen if you are grounded in some manner to the source or touching neutral. Standing on the ground would do it. Touching a metal plumbing pipe or fixture would do it. You can hold a live 120 vac wire if you are completely isolated from any other path to the power source.
https://www.dummies.com/article/technolo........cs/closed-open-and-short-circuits-141399
dogvetia
papillion, nebraska
This has been an enlightening dissertation on how a gif circuit works and I appreciate all the replies but I still don't see why 50 amps coming from a post or generators and coming thru the same plug in the side of the rv should affect the bathroom gfi outlet has two total different actions. Both sources travel thru the same wiring paths so why does the gif outlet interpret them differently?
2012 F350 diesel
2018 cruiser lite 28rd
BB_TX
McKinney, Texas
Get a tester like shown below and plug into a working non GFCI outlet. Then connect RV to shore power and check for correct power. Then plug RV into your generator and again check for correct power. I am thinking you will find an open ground when connected to generator.
Tester
JRscooby
Indepmo
BB_TX wrote: Get a tester like shown below and plug into a working non GFCI outlet. Then connect RV to shore power and check for correct power. Then plug RV into your generator and again check for correct power. I am thinking you will find an open ground when connected to generator.
As a CG host in a state park all I was allowed to do when a camper complained about power issues was plug that type tester into the post, using what adapters needed (50-30, 30-15, you know, things that can burn snot down if miss used) If the lights came on as expected, "Sorry, the issue is in your camper." Now, unless the camper was acting like Richard Noggin, I would ask if they had any outlets not controlled by GFI, and offer to let them plug my tester in. It would tell them the issue.
The breakers in your panel trip when currant flow exceeds limit. But because some things put a much larger load on for short time they will handle large load for short time. If breaker let the starting load run for long that little wire would burn up, maybe burn the house down Breaker don't know if that extra load is starting the garbage disposal, or if the maid is touching a bare wire and the faucet. In the time it takes to start the motor, the maid might be dead.
GFI, compares hot and neutral. Normal operation there is no reason for there to be a difference, so instantly stops flow.
Breakers and fuses are to protect things, GFI is to protect people.
jkwilson
Indiana
My bet is you aren’t getting both legs of power when on shore power. Either the cord is bad, shore power is bad, cord is loose in the plug on the trailer or a very common failure of a bad transfer switch. Fairly easy to verify at your panel.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
