time2roll
My OEM ducting was inadequate. I added 2x 4" additional ducts and the furnace works so much better with tons more heat and the burner stays on the entire cycle.
675w Solar pictures back up
groundhogy
PA
Cat hair and lint blocking incoming air?
Its just a bunch of slats in the furnace box
Gdetrailer
PA
dougrainer wrote: "Regulator malfunction can result in higher propane pressure to the furnace which affects flame size.. Check the burners on your stove, flame should not be excessively high and should be all blue".
This will not work. The Stoves/Ovens have their own regulator set at 10 inches water column. So if the LP regulator is too high this regulator will fix that for the Oven/Stove. Doug
RV furnace gas valve also has "it's own" regulator same as a home gas furnace and even home gas stove and oven, but those also can be affected by the incoming gas pressure if it is too high or too low..
Gdetrailer
PA
time2roll wrote: My OEM ducting was inadequate. I added 2x 4" additional ducts and the furnace works so much better with tons more heat and the burner stays on the entire cycle.
I believe OP has had this RV for a while and this IS a recently new "symptom".. If I am correct, that would make the assumption of not enough ducting not much of an issue unless a new blockage has been introduced (like a blanket covering a register?)..
time2roll
Gdetrailer wrote: time2roll wrote: My OEM ducting was inadequate. I added 2x 4" additional ducts and the furnace works so much better with tons more heat and the burner stays on the entire cycle.
I believe OP has had this RV for a while and this IS a recently new "symptom".. If I am correct, that would make the assumption of not enough ducting not much of an issue unless a new blockage has been introduced (like a blanket covering a register?).. OK and mine malfunctioned for almost ten years before I dug in and fixed it.
JKJavelin
Milwaukee, WI
Mine seems to do this more in higher elevations. At sea level, it runs steady.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023-
Dusty R
Charlotte Michigan 48813
Also the squirrel cage fan can get dirty and cause it to not move enough air.
dougrainer
Carrolton, Texas
Gdetrailer wrote: dougrainer wrote: "Regulator malfunction can result in higher propane pressure to the furnace which affects flame size.. Check the burners on your stove, flame should not be excessively high and should be all blue".
No it does NOT. It only has a 2 stage electric LP solenoid valve. But that is not a "regulator". The only appliance in an RV with its OWN regulator is the Oven/Range. Doug
StirCrazy
Kamloops, BC, Canada
probably a rech, has anyone played with the anticipation setting in the thermostate. when I got my camper it was short cycling like crazy then I looked at that and set it back yp to factory andit works good. trying to figure out what I can replace it with now that I don't have to buy from a rv shop that maybe will be a little better at the heat swing.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
dougrainer
Carrolton, Texas
StirCrazy wrote: probably a rech, has anyone played with the anticipation setting in the thermostate. when I got my camper it was short cycling like crazy then I looked at that and set it back yp to factory andit works good. trying to figure out what I can replace it with now that I don't have to buy from a rv shop that maybe will be a little better at the heat swing.
Steve
If you have an electronic Tstat, there is no anticipator setting. Doug
