RV.Net Open Roads Forum: Fifth-Wheels: Step to reach hitch pin
 > Step to reach hitch pin
Page of 7
Cummins12V98
on the road
Posted: 03/06/22 10:33am Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
MFL wrote:
rhagfo wrote:
Likes to tow wrote:
Had the same issue reaching my B&W handle and pin. I'm 5'7" and 75 so trying to put my foot on top of the tire was not a good solution. I found a tire step on Amazon and it works perfectly plus it folds up and I lay it in the floor behind the driver seat in the truck. Check it out
https://www.amazon.com/s?k=tire+step&crid=1ACA51XEMAIFH&sprefix=tire+ste%2Caps%2C126&ref=nb_sb_ss_ts-doa-p_2_8
Link
My issue is the hips on our DRW make it a bit of a reach,
^This is a case of TOO much truck! A SRW would be more than sufficient for your trailer, problem solved! [emoticon]
Just had to, no offense,
Jerry
Well I would have maxed out the payload on the same year Ram CC LB with 12,300# GVWR and 4,200# payload! We lost 1,411# of payload to us, Belle, in bed tool box and hitch. The pin on our 5er is 2,700# or total of 4,111# that is a bit close.
This is something many miss when looking at payload, it isn’t just the pin weight, it is everything added to the TV.
How does that compare to the SAE RAWR of the SRW 3500?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 03/06/22 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Likes to tow said: "I actually use a pad lock on my B&W instead of the pin. I'm afraid someone will remove my pin while I'm not looking and then watch me drop my 5th wheel on the truck bed."
I can't tell you how many times I have been given CHITZ for my locking of so many items!!! Good idea that you add locks to the head also IMHO.
FYI the head pins need to be bent at a 90 or they can simply be rotated and pulled out. They are not bent in pic below. I heated mine with a torch. Had to drill holes out a bit larger for the lock and countersunk the holes a bit on each side.
larry barnhart
wenatchee. wa usa
Posted: 03/06/22 10:54am Link  |  Quote  |  Print  |  Notify Moderator
I have always locked our hitch. just common sense thing to do and now with a lawless country it is really a good idea.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
on the road
Posted: 03/06/22 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Here are the pins after modification.
Lantley
Ellicott City, Maryland
Posted: 03/06/22 11:45am Link  |  Quote  |  Print  |  Notify Moderator
chevman
I consider the lock more of a liablity and safety issue more than a security feature.
I've considered having to detach my truck from the trailer real quick in the event of a fire in the RV. I know/heard of lots of examples of RV fires. I've experience a wheel fire myself.
I'm more concerned about a quick detach scenario vs. the latch release guy.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cummins12V98
on the road
Posted: 03/06/22 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Not worried about it as I always have my hitch key in my pocket.
GaryUT
Northern UT
Posted: 03/06/22 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I use a plastic milk crate with a square piece of plywood on the bottom. When its not being used for a step the wheel chocks go in the crate and it rides in the bed of the truck.
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
Retired JSO
North Georgia Mountains
Posted: 03/06/22 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I’m 5’-10” and 72 years. I step up on the outside dual rear tire to unhitch my B&W Companion hitch.
Goostoff
Wisconsin
Posted: 03/06/22 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
mhardin wrote:
I use a folding plastic step LIKE THIS. They come in a number of different brands and costs.
This is what I use as well. Just fold it up and toss it in the truck beside the hitch.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Cummins12V98
on the road
Posted: 03/07/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Mine is barely visible, tucks away nice and neat.
Page of 7
