RV.Net Open Roads Forum: Fifth-Wheels: Step to reach hitch pin
 > Step to reach hitch pin
Page of 7
Mote
Hoosier State
Posted: 03/07/22 10:09am Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
Likes to tow wrote:
Had the same issue reaching my B&W handle and pin. I'm 5'7" and 75 so trying to put my foot on top of the tire was not a good solution. I found a tire step on Amazon and it works perfectly plus it folds up and I lay it in the floor behind the driver seat in the truck. Check it out
https://www.amazon.com/s?k=tire+step&crid=1ACA51XEMAIFH&sprefix=tire+ste%2Caps%2C126&ref=nb_sb_ss_ts-doa-p_2_8
Link
I gave your steps a link. My issue is the hips on our DRW make it a bit of a reach, this works great. Unlike folding stool/steps, it won't kick out when you lean in.
I think I'll have to get one those you've put a link for. I will typically climb up on the outside dually tire to lock and unlock the hitch and then jump down. This will make it a lot better for my knees. I could see myself also using this on the front tire to get up to wash the windshield.
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
MFL
Midwest
Posted: 03/07/22 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Mine is barely visible, tucks away nice and neat.
IMO 12V has the best idea/product, for the intended use!
My plain, simple, but multi tasking Rubbermaid step stool, with rubber slip free surface, works great for many things. I use it to clean bugs from windshield, as a table to hold my beverage/other items. It is an extra step, when 5th is parked on uneven ground. I keep it behind cab, in bed corner, upside down, with my chocks inside.
Made in America, as is 80% of Rubbermaid products!
Jerry
Cummins12V98
on the road
Posted: 03/07/22 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Thanks! I put a lot of time into making it a functioning product.
My Dad bought the AMP and returned it as it mounted at the front of the bed. That got me thinking there had to be a better way.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Tzman4
Mesa, AZ
Posted: 03/08/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Ditto mhardin, I also use the plastic folding stool.
Dennis & Patty Martin, Sami & Sassy
2011 F450 KR
2021 Forest River RiverStone Legacy 42FSKG
2020 HD FXST
blofgren
Surrey, B.C.
Posted: 03/08/22 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Link
I have one in my shop so if you come North of Seattle I will make you a great deal. The AMP step is useless as it mounts at the front of the bed so I created the perfect bed step IMHO.
That looks great; you should make up a bunch of them and sell them! I'm assuming that there must be a section of larger steel tube mounted to the frame that it slides in to?
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Cummins12V98
on the road
Posted: 03/08/22 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the compliment.
My wife thinks I should sell them. Too many other things to do!!!
StirCrazy
Kamloops, BC, Canada
Posted: 03/09/22 06:48am Link  |  Quote  |  Print  |  Notify Moderator
my handle and such is right abovve the tire, so a side step wouldnt work unless I was trying to climb into the box. I just use the center hub of the rim and the tire top to climb up and stand on.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Cummins12V98
on the road
Posted: 03/09/22 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Mine is placed perfectly between the hitch and tool box giving easy access to both.
larry barnhart
wenatchee. wa usa
Posted: 03/09/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
the plastic folding stool has worked great for me to fuel the in bed tank and many others reasons. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
MFL
Midwest
Posted: 03/09/22 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Makes me wonder if Steve's hitch is a brand X, rather than a fanboy hitch??
Cummins12V98 wrote: "Mine is placed perfectly"
Ha, why did I already know that? I am that same guy![emoticon]
Jerry
Page of 7
