RV.Net Open Roads Forum: Tow Vehicles: DEF when towing
Search only in Tow Vehicles
 > DEF when towing
FishOnOne
The Great State of Texas
Posted: 03/06/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
With recent fuel prices skyrocketing, not sure if DEF consumption is a really big deal.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
Posted: 03/06/22 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
At least they include lube.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Huntindog
Phoenix AZ
Posted: 03/06/22 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I am now on my third Duramax.
My current one is a 2020. I do not use them for daily driving. They have all been 90%+ towing. I can say that this one uses a lot more DEF than the others.
GM obviously expected that, as this one has a larger tank.
It is what it is.
Having fun costs money. How much fun do you want to have?
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Posted: 03/06/22 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
We’re now almost 1/4 of the way through the 21st century.
Self driving vehicles actually exist, and the big 3 can’t figure out how to incorporate an accurate gauge for a consumable fluid, that is slightly more important than, say, windshield washer fluid!
Maybe glass sight gauges shouldn’t be a thing of the past! Lol
On a different note, I wish the def gauge in our truck was only part of the information screen and not an actual gauge. Because it looks like I have a broken gauge in the cluster since it’s been sitting below E since 2016….
Toolguy5
Columbia Station, Ohio
Posted: 03/07/22 05:49am Link  |  Quote  |  Print  |  Notify Moderator
It is what it is.
That is what I am noticing but i will find out if i have an issue
Dan & Patty
Miss Pickles the Pomeranian Princess
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
mkirsch
Rochester, NY
Posted: 03/07/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
DEF freezes when it's extremely cold. So I would expect some unexpected results when the DEF is frozen which clear up after the DEF thaws out.
ksss
Eastern Idaho
Posted: 03/07/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I would agree that the '20 uses more DEF than the older trucks use. Same L5P engine, but they clearly dialed up the DEF.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Toolguy5
Posted: 03/08/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
just picked up truck from Dealer. Could not find anything wrong with my DEF system. GM did issue an article revised February 3rd 2022 on Excessive Diesel Exhaust Fluid. The gauge is only a reference and may need several key cycles to show actual amount in tank. The rate of DEF will vary on Temperature, Altitude, speed and load. So the harder engine works the more DEF.
They Also stated as the NOx reduction requirements increase the more the newer vehicles will use. I guess 2020 was a reduction requirement year.
Article also states that if you receive message of XXX amount of miles that may not be accurate as well. It could decrease or increase depending on conditions and load of engine.
 > DEF when towing
