RV.Net Open Roads Forum: General RVing Issues: Locking gas cap
 > Locking gas cap
Posted: 03/07/22 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Seattle Steve wrote:
NamMedevac 70 wrote:
I also use locking gas caps on 3 trucks, but they are easy to break off with a screwdriver. YouTube post many videos of how to do this and it works in less than a minute. Not too noisy unless they also use a hammer. I have done it when lost a key.
Not only is it easy, but they couldn't care less about how much paint damage the do taking it off. Cheaper in the long run to just let them take the gas.
Good point. Like locking your vehicle.
On jobsites with theft issues, we leave job trucks unlocked. Beat's replacing a window or punched in door lock, etc, just for the thief to find nothing of real value.
Not sure what treasure they think is left on the side of a freeway in a dirty old pickup with a couple pairs of used gloves, some earplugs and a grungy safety vest maybe laying on the seat.
Posted: 03/07/22 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
No locking gas cap they stick a siphon hose in the tank and drain you.
Locking gas cape they crawl under and punch a hole in the tank.
mockturtle
AZ
Posted: 03/07/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hate to have to say this but the best solution is to stay with your rig when you're not in a secured park. [emoticon]
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Fisherman
Angus, Ontario, Canada
Posted: 03/07/22 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
How about a small sensor inside the gas tank door that sets off an alarm in your cell or added to the vehicle alarm.
NamMedevac 70
Reno
Posted: 03/07/22 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
For over twenty years now including camping, hiking, fishing in remote areas and parking in big cities such as SFO never a problem with my three trucks. I love my locking gas caps and two prong steering wheel locks that are highly visible from the outside. Whatever floats your boat then do it. TTB SAB
Now let us debate how many angels can dance on a pin head. IFSSFY
pianotuna
Regina, SK, Canada
Posted: 03/07/22 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
They sometimes cut the filler tube. DAMHIK.
Regards, Don
pbeverly
South Carolina
Posted: 03/08/22 04:29am Link  |  Quote  |  Print  |  Notify Moderator
I had a lock cap for a truck once and lost the key. Did a little research and learned they are designed to easily bypass the lock with a simple tap with a hammer and screwdriver.
Ridgeway, SC
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 03/08/22 06:20am Link  |  Quote  |  Print  |  Notify Moderator
My RV's gas filler is recessed. I bought a universal "door" and put it over the opening and added a micro switch tied to the alarm. When armed, it works the same as someone opening a door. The only issue (didn't think of this when doing the initial install so had to redo it) I need to hold the fuel nozzle at an angle so I ended up having to orient the hinge at the top. The door doesn't have a lock as I use a locking gas cap. The purpose is to get any thief to open that door to trigger the alarm.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
PastorCharlie
NC
Posted: 03/08/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Which cost less a tank full of fuel or new tank? I choose not to require them to rupture my tanks.
HarleyEnough
PA
Posted: 03/08/22 11:43am Link  |  Quote  |  Print  |  Notify Moderator
The locking gas caps are mostly just for piece of mind. I had a used Jeep Wrangler I bought as a daily driver that came with one but no key. It was locked but a key wasn't needed. Just firmly squeeze the edges of the gas cap together while turning and it spins right off. Squeezing the edges together keeps the outer shell from turning freely when locked so you can still take the cap off.
2011 Dodge Ram Laramie 3500 Crew Cab Long Bed SRW
2019 Raptor 421CK Full Body Paint
 > Locking gas cap
