RV.Net Open Roads Forum: Truck Campers: Micro-Air/RecPro AC problem
 > Micro-Air/RecPro AC problem
jerryb4
Wisconsin
Posted: 03/07/22 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
Updating AC on my Lance 1120, decided on a RecPro RP-AC2801 low profile. When I went to mount the Micro-Air 364 I removed from the old unit I cannot figure out where to mount it, it is really tight inside the AC unit.
Anybody added a Micro-Air to one of these and if so, where the heck did you put it ?
Thanks,
notsobigjoe
southeast
Posted: 03/07/22 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have no idea where to put it in your new unit but the one I installed was completely water proof at least that's the way it looked to me. Mount it in a different place? Just some input to the problem, good luck!
Joe
jimh406
Western MT
Posted: 03/07/22 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
First question, why do you think you need it?
jerryb4
Wisconsin
Posted: 03/08/22 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I contacted Micro-Air, quick response, a plug for that company-they have always responded very quickly to any questions, nice. The unit is rated for outside. As to why needed, when I am boondocking and want air (not to often) I use my Honda 2200, as I had the 364 on the old unit might as well make life as easy as possible for the gen.
Thanks for the responses.
ScottG
Bothell Wa.
Posted: 03/08/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Keep this in mind. If the factory cap dies while the AC is running, it will stop and no harm is done. If you have a hard start cap installed, it will allow it to keep running and it will destroy the compressor.
So if you don't need it, don't use one.
3 tons
NV.
Posted: 03/10/22 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
The micro-air is neither a factory cap or hard start cap, so I not real sure what your cap point is about?
3 tons
JoeChiOhki
Sauvie Island, OR
Posted: 03/11/22 04:15am Link  |  Quote  |  Print  |  Notify Moderator
For those not familiar with the A/C in question:
RecPro RP-AC2801
As to the original question, I'm not sure if these were designed to support the RecPro line, as they do not include any wiring diagrams for that model line, though they do have a generic wiring diagram that does not appear to remove the run capacitor completely from the circuit.
If I was to guess, your only option would be in the middle left hand side between the front and rear sections in the housing, attaching it in some fashion to the side of the inner shroud that I believe houses the cabin air fan housing.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
trail-explorer
NM
Posted: 03/11/22 09:43am Link  |  Quote  |  Print  |  Notify Moderator
The need for one is to "soft-start the A/C" when running on a small generator.
That's the whole purpose of the Micro Air Easy Start. It starts up the cooling fan first, then after a delay it starts up the compressor.
ScottG wrote:
If the factory cap dies while the AC is running, it will stop and no harm is done. If you have a hard start cap installed, it will allow it to keep running and it will destroy the compressor. So if you don't need it, don't use one.
So what are you saying? Don't use a factory cap and don't use a hard start cap?
Your post is confusing because it implies you need one (a cap) but then you say "if you don't need it, don't use one."
The Micro-Air is neither a factory cap or hard start cap, so I'm not real sure what your cap point is about.
* This post was edited 03/11/22 10:17am by trail-explorer *
Bob
jimh406
Western MT
Posted: 03/11/22 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
My point, since you missed it, was that just because he needed the Easy Start for the old AC doesn't mean he needs one to start the new AC.
jerryb4
Wisconsin
Posted: 03/13/22 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
up date:
The RecPro RPAC-2801 is very tight inside, really compact and well sealed. I would have to mount the Micro-air outside the shroud secured to the camper roof. To access the compressor capacitor(which is needed to install the Micro-Air) I would have to do some dismantling, more then I want to at this point, so, I am going to install and perform trial runs with Honda 2200. Will try checking amp draw and function. Will update when possible.
