RV.Net Open Roads Forum: Tow Vehicles: Fresh fluids and four new tires
Search only in Tow Vehicles
 > Fresh fluids and four new tires
FishOnOne
The Great State of Texas
Posted: 03/11/22 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I'm surprised to see ya'll use a German word up North.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
alexleblanc
Moncton NB
Posted: 03/14/22 07:23am Link  |  Quote  |  Print  |  Notify Moderator
4x4ord wrote:
^^^ Going from a 2017 to a 2022 you're going to find your doppelgänger is not really a doppelgänger. The newer Powerstroke and 10 speed is incredible .... will your '22 have the 3.31 rear gears?
I ordered the 3.55 rear gears not knowing if i really needed them or not.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
alexleblanc
Moncton NB
Posted: 03/14/22 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I have have several German cars in my garage, need to keep up on the lingo i guess!
4x4ord
Alberta
Posted: 03/19/22 05:44am Link  |  Quote  |  Print  |  Notify Moderator
You might want to consider changing your order to 3.31 gears. My 2021 had 3.31 gears and I was very pleased with its fuel economy. My ‘22 has 3.31 gears as well but I can’t yet comment on its mileage. Unless someone is continually towing a 20,000 lb triple axle toy hauler 3.31 gears are a better choice than 3.55. With 3.31 gears there may be times that you are towing in high winds or up and down hills that you choose to lock out 1 or 2 gears but with a 16,000 lb trailer in tow 3.31 gears will actually out perform 3.55 gears on a 6 or 7% grade. First gear with the new Powerstroke/ten speed and a 3.31 final drive is capable of putting more torque to the rear axle than a 2017 F-450 can in first gear with 4.30 gears.
2022 F350 SRW Platinum short box 4x4.
B&W Companion
alexleblanc
Moncton NB
Posted: 03/25/22 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Order is changed to 3.31's, if it's even a bit better on fuel and the towing is better then my 2017, i will be happy.
