RV.Net Open Roads Forum: Tech Issues: Lithium batteries and alternator protection.
 > Lithium batteries and alternator protection.
Page of 8
theoldwizard1
SE MI
Posted: 03/12/22 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Also 13.2V would not be a issue for me as it indicates a charged battery and the alternator is only supplying chassis and converter loads. A higher voltage indicates the chassis battery is drawing amps so at least the DC-DC converter has less conversion losses.
Almost all vehicles for the past 15-20 years or so, use some kind of a smart charging system. The voltage from the alternator is controlled by the engine computer and can vary over a wide range.
Tom_M
New Hope, MN
Posted: 03/13/22 03:31am Link  |  Quote  |  Print  |  Notify Moderator
I have had my Renogy 170ah lithium battery for 2 years and have had no issues with it hooked directly to the alternator.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
CA Traveler
The Western States
Posted: 03/13/22 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Does this apply to MH engines delivered w/o an alternator which is upgraded to a larger alternator due to the larger power demands? Is there any additional information on this subject?
2014 Grand Cherokee Overland
Bob
theoldwizard1
SE MI
Posted: 03/13/22 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Does this apply to MH engines delivered w/o an alternator which is upgraded to a larger alternator due to the larger power demands? Is tbhere any additional information on this subject?
Smart charging started in cars but moved to all Ford produced vehicles fairly quickly. The size of the alternator did not matter.
What additional information do you want ? To see it in action, turn just the headlights on for about 5-10 minutes. Hook a multimeter directly to the battery. Start the MH and hold it at a high idle. The initial voltage will be in excess of 14V. It will drop within a few minutes. After about 5-10 minutes of high idle, the voltage will drop down to about 12.6V - 13.2V. This is lower than any conventional alternator/regulator.
S Davis
Western WA
Posted: 03/13/22 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Not on 2009, 2013, 2019 GM 2500HD diesels, my last three trucks all have had steady voltage at about 14.2 no matter what. They must be in the almost none category.
One of my Redarc 50 amp chargers pulls 50 amps from the alternator and output is about 46 amps to the batteries, so on Redarc it looks like the rating is what is pulled from the alternator.
BFL13
Victoria, BC
Posted: 03/13/22 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
https://cdn.shopify.com/s/files/1/2204/8........which_alternator.pdf?9828243052323048027
Says the 50A Redarc has rating 50A output at 750 watts with 60A fuse for both input and output. 750/50 = 15v
see specs link here:
https://redarcelectronics.com/products/d........-input-50a-in-vehicle-dc-battery-charger
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 03/13/22 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance a measurement of the charging amps was noted? Please post if available.
675w Solar pictures back up
CA Traveler
The Western States
Posted: 03/13/22 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
In that case my 09 RV, 14 Jeep and 19 Lincoln don't have smart chargers.
My understanding is smart chargers lower the voltage to compensate for the increased car electronic load and hence less alternator load. However the batteries still have to be first charged at higher voltage. So how does that translate into a MH with 2 larger battery banks and higher loads?
Tom/Barb
Oak Harbor, Wa
Posted: 03/13/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Tom/Barb wrote:
This is what we did, A 30amp DC to DC charger gives you the ability to charge the coach battery bank while running the coach engine.
This limits the engine alternator to 30 AMPs thus prevents overheating the engine alternator....
Do you still believe that ?
Hope the OP doesn't .
Yes.
Our equipment is operating as it should, 2 years in, set IAW Victron's settings .
So why shouldn't I believe that?
Some folks wouldn't believe, even when the proof is in front of them.
otrfun
On The Road
Posted: 03/14/22 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Yes.
A 30a dc to dc charger producing only 20a of charge current indicates 1) a very inefficient dc to dc charger with only 66% conversion efficiency, 2) an installation experiencing excessive voltage drop due to undersized cabling or bad terminations, and/or 3) a 20a dc to dc charger that is improperly rated as a 30a charger.
Our 40a dc to charger outputs 40a of charge current with only a 43.5a draw on the alternator—-92% conversion efficiency. The manufacturer recommended 4 gauge for our run length. We used 2 gauge cabling to minimize voltage drop and maximize conversion efficiency.
Page of 8
