RV.Net Open Roads Forum: Tioga Won't Budge after long neglect. Help, please.
 > Tioga Won't Budge after long neglect. Help, please.
211Racing
Texas Hill Country
Posted: 03/13/22 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
There is zero -0- fuel pressure in the fuel rail. I'd be delighted if it was old gas, but I think its worse than that. I have no history of the vehicle before 2018. From 2018-2021 it was used to attend music festivals. No shore trips reported. Caliper pins ... I'll try to give those a closer look. I crawled underneath today and did see rust on the rotors. Gave them a good spray of CLP (works on rusted firearms). Will clean those rotors once the wheels move freely and the pads give them a little polish. I intend to jack it up tomorrow and try to move individual wheels so as to narrow my focus.
time2roll
Posted: 03/13/22 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Did the truck get it to the shop?
675w Solar pictures back up
211Racing
Texas Hill Country
Posted: 03/13/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Question(s) for all: Towing. 1. Does any part of the drive train need to be disconnected to tow this with two wheels on the road? Four wheels? Why would I ask? The fine folks at AAA have been unable to connect me with a tow service that is capable/willing to move this 24' vehicle. (Save one, that wanted $1000 for the 23 mile trip.) Which leads us to question 2. Am I limited to semi-truck heavy-haul tow trucks to get this tow done? Pardon the rookie questions, but at 24' and 11,000 lbs a mega-tow-truck hardly seems warranted.
211Racing
Texas Hill Country
Posted: 03/13/22 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
so
Unfortunately, no. Dude rolled up with a 20' flatbed. Took pictures. Called his boss. Said "Sorry man, boss said no." and turned around and left.
Gdetrailer
PA
Posted: 03/14/22 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Generally, not a bad idea to disconnect drive shafts on most automatic transmission vehicles unless specifically stated in the owners manual that it is OK to tow long distance at speed.. Dropping the drive shaft on most rear wheel drives is not all that complicated.. However being you have a 1 ton van chassis which has the potential for being stretched in length may be complicated a bit with a carrier bearing.
Most smaller tow trucks and flat beds are designed for smaller and lighter loads and may not have enough lift, engine, brake capacity to safely tow the combined weight of the wrecker plus your Tioga.. Wreckers and flatbeds are heavy when outfitted for duty. Matter of fact, once you do get this beast running you will find that the engine you have is going to be pretty much maxed out to haul it's self around when loaded for camping..
BFL13
Victoria, BC
Posted: 03/14/22 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Both RVs in sig had to be towed in last few years. Class C and then the truck with camper on it. They used a "medium duty" like here -scroll down-
https://www.totemtowing.com/our-fleet/
With the truck and camper, Good Sam asked if the camper was on it because they thought it would be too high on a flat bed to go under wires and bridges. Be too high with a Class C too maybe.
The tow truck has big bar things on each side out back to clamp the front wheels and lift them off the ground. They took the pins out of the drive shaft at the back underneath. (Makes sure the driver doesn't leave afterwards with those pins still in his pocket! [emoticon] )
Had to pay extra per GS rules for going farther than the nearest garage, but it sure wasn't $1,000.
Watch they don't lift the front so high the back of the RV will be too close to the ground, depending on the terrain en route.
* This post was edited 03/14/22 10:22am by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 03/14/22 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Consider a mobile mechanic that will do chassis work.
211Racing
Texas Hill Country
Posted: 03/14/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Found the Problem!
Jacked up the wheels one at a time. First three were reluctant to move, but after a few rotations all spun easily. Did the left front last. Very little movement initially. I worked it back and forth until I heard something break free. Looked, and found the friction pad had snapped off the rest of the brake pad and was stuck to the rotor. I'd post images but I haven't figured out yet how to do that on here. Fascinating that the adhesive between the friction pad and the rest of the brake pad gave way before the rust-adhesion to the rotor. Definitely the first time I've seen that.
Bobbo
Wherever I park
Posted: 03/14/22 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
The first post in this thread tells you how to post photos easily.
How to post pictures.
Bobbo and Lin
olfarmer
Iowa
Posted: 03/18/22 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
It shouldn't be that hard to tow a 24' class C. I have had our 31" class A towed twice. They had a medium sized truck that could lift the front wheels off the ground. They did disconnect the drive shaft which would also disconnect the park brake if it is behind the transmission. The first time they towed us 70 miles, the second was probably about 20. I don't know what the first tow cost as my towing insurance paid for it, the second was around $350 if I remember right. I did get reimbursed for that after I got home. We had Good Sam towing insurance. Good luck and let us know how you come out!
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
