bgum
South Louisiana
Door weather stripping would be my guess.
hornet28
Muskegon Mi.
You're wondering if it's the cab lights, I've had more than one truck with cab lights and never experienced any whistling. One thing you could do is take a screwdriver and make sure all screws on those lights are tight
s1214
Vt
2019 2500HD with the towing mirrors. At certain speeds and wind direction the mirrors whistle. If I extend the mirrors out a little, it stops.
BenK
SF BayArea
With the hose method, have helped ID sources :
2 Windshield. One at the middke bottom. Other upper, pager corner
Several door, door window
One down on the floor where a drain plug wasn't reinstalled correctly
The hose should be about 3-4 foot long
Good luck
-Ben Picture of my rig
bucky
Raleigh metro
Sorry, misread something.
Puma 30RKSS
PA12DRVR
Back in God's Country
"2019 2500HD with the towing mirrors. At certain speeds and wind direction the mirrors whistle. If I extend the mirrors out a little, it stops."
Several years older model with the same issue. Pull the mirrors out just a bit (.5" or so) and it stopped. 13 years later, apparently enough crud has built up that it doesn't happen anymore.
Had the same noise issue on a Toyota Tundra: fixed by putting a strip of black electrical tape over a seam in the mirror housing.
CRL
My RV is a 1946 PA-12
Back in the GWN
HTElectrical
Las Vegas
Check the trim around the front windshield. With my bug deflector on my truck it caused a whistle tapping noise at highway speed. I taped around window and outside, and filled slight gap with black caulk. No more noise.
2007 Duramax, Cognito 7"-9" Lift,
