schlep1967
Harrisburg, PA
So much for creating easy access. If you do replace the check valve in the future, pay attention to the direction of flow arrow. It won't matter on the gutted one you have now but it will on a working one.
Did you find all of the old pieces of the check valve?
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
lane hog
Tucson, AZ & NW Chicago Burbs, IL
With all the generator advice Mr. Wizard has given over the years, it pains me to see him having this kind of trouble with something that shouldn't be this difficult to fix...
- 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
- 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
- 130W solar and 2005 Honda EU2000i twins that just won't quit
dougrainer
Carrolton, Texas
The ONLY reason a W/H would require a check valve is if it is part of the Bypass system, that uses a handle and not the 3 valves behind the Water Heater. YEARS ago, RV's built in California required the check valve due to state plumbing codes. Once California dropped this requirement for RV's they stopped installing them. The problem with Check Valves that are NOT part of the Bypass system is, the usually had a squealing/humming noise when water flowed thru them. National Motor homes(built in California) were the brands we sold and serviced. We would remove the check valves when customers complained about the noise. National were the ones to inform us about the California code that required that check valve. But since our customers were not in California, we could remove the check valve. I always use and tell people to use the BRASS CHECK VALVE when replacing a faulty check valve. In this case, if you HAVE a single lever Bypass valve, Odds are you need to have that valve installed to make the Bypass system work correctly. Doug
MrWizard
Traveling
Doug thanks for the info,
I don't winterize , because I'm full-time,
I'm just glad to have hot water flowing again
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
MrWizard
Traveling
Schlep
I installed it the correct way, there was no way to put this one.backwards, in this install, input end is male threads into the wh, the output is female, brass elbows is male on both ends , HW..line female connect to elbow,
Found the plunger/gate no spring, the first elbow in the system is the one attached to check valve, I think that spring rusted away sometime ago, nothing but water came out when I blew out the line
Before cleaning
edited 03/29/22 04:38pm by MrWizard *
enblethen
Moses Lake, WA
No offense, but I think I would have replaced the check valve with a brass one.
I also saw what looked like calcium type deposit in the one fitting. That could be an indication of build-up in water heater tank. How often do you flush the tank?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gottahaveit
Stockton CA
Woooo Hoooo George !!! Glad you got it fixed and have some awesome hot water again. Miss seeing you and happy to see your posts. Had us Mods worried for a bit
40ft Mandalay Quad Slide
2015 Jeep Grand Cherokee Limited
MrWizard
Traveling
Yes there was some calcium deposit, I cleaned out of the elbow, there could be some in the WH but all I ever get when flushing or draining is clear water, any deposits are harden and pre-existing from the previous owner, I was surprised when I saw the deposits in the elbow and check valve,
I thought about removing the pop off valve and pouring a few gallons of CLR into the water heater via a funnel and letting it soak overnight, put it on bypass leave it turned off,
Then drain & flush the next day
Any body try this,
I've been looking at Cellphone Borescopes online , it's been several times now that I could have used one to inspect a problem situation
MrWizard
Traveling
Before being removed
![[image]](https://i.imgur.com/Xbj8pmOl.jpg)
Before being separated and cleaned
enblethen
Moses Lake, WA
I have used white vinegar on faucets and shower heads. 50/50 vinegar and water.
If it is the bottom (where it normally is) you would not mush over two gallons of mix.
