RV.Net Open Roads Forum: Tow Vehicles: Oil changes with synthetic
Search only in Tow Vehicles
 > Oil changes with synthetic
Page of 8
pasusan
Northernmost PA
Posted: 03/16/22 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
How often do you change your oil if you use full synthetic oil?
We have a Chevy 6.0 gasoline engine. We are putting Mobil 1 synthetic oil into it and are finding differing requirements. Some say go by miles, others say if you don't put on that many miles change it every year.
We only drive it 2000 to 3000 miles per year. Can we really wait for 7000 miles or more to change it or should it be done every year?
My thinking is why go synthetic if you have to do it every year anyway?
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
wildtoad
Blythewood, SC
Posted: 03/16/22 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
IMO if you only do 3k miles a year, you should still change the oil and filter annually. At the same time, there is no valid reason to pay for higher priced synthetics. Use the oil spec suggested by your manufacturer, and do a once a year oil change, lube (if appropriate), fluid checks, tire inspection.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Southern California :(
Posted: 03/16/22 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
“How often do you change your oil if you use full synthetic oil?”
Whenever Chevrolet says “change the oil” on the truck. On the very low mileage 2018 Equinox, when Chevrolet says “change the oil’…about every year.
FishOnOne
The Great State of Texas
Posted: 03/16/22 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ Agreed...
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
dodge guy
Bartlett IL
Posted: 03/16/22 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
With that little mileage once a year is needed.
With that said I change my oil every 4K with Mobil 1. Yes it is overkill, but I have never had an issue. I really wouldn’t want to wait for 7k-10k miles.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
theoldwizard1
SE MI
Posted: 03/16/22 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I disagree. You can extend the time but ONLY IF THE ENGINE GETS USED !
Biggest problem with any engine oil is water contamination. Water gets into the oil, when you do a lot of short trips. Once every month or two, take a highway trip of at least 30 minutes, 60 is better. The oil will be sufficiently hot that any moisture will be gone.
Not sure if I would push it past 2 years.
Cummins12V98
on the road
Posted: 03/16/22 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Only real way to know if you can do extended oil changes is doing an oil analysis.
Contact Blackstone Labs they will send you postage paid kit.
* This post was edited 03/16/22 09:07pm by Cummins12V98 *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
specta
utah
Posted: 03/16/22 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Change it.
Once a year is nothing.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 4wd Mercury Marauder 410 4V
Regular cabs. The best looking trucks.
pasusan
Northernmost PA
Posted: 03/16/22 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
OP here - thanks guys for the replies!
I think I see the reasoning for every year if you don't put too many miles on - thinking that the driving is all short duration...
Our 3000 miles are all trips - long distance highway miles. I think we should be safe with every 2 years.
Correct me if I'm wrong. [emoticon]
ksss
Eastern Idaho
Posted: 03/16/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
There are some engines I wouldn't wait two years on, but the 6.0 is not one of them. Being synthetic, I would go two years, and have the oil tested at the end of the 2 year period then you would know for sure. I think you would be more than fine after the two year period. I use Blackstone lab as well.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Page of 8
