RV.Net Open Roads Forum: Tow Vehicles: Oil changes with synthetic
Search only in Tow Vehicles
 > Oil changes with synthetic
Page of 8
larry barnhart
wenatchee. wa usa
Posted: 03/19/22 11:20am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
mosseater wrote:
Many years ago, when Hector was still a pup, and folks still believed in silly things like objectivity, Consumer Reports did a pretty thorough test with NY city taxi cabs and oil changes. Sythetic was still a niche market then, but after running taxis for 100K miles on almost all readily available oil brands, they tore them down to inspect and measure. The conclusion was, as long as the oil was changed at the then-standard 3000 miles, it didn't matter if it was mobile one or PepBoys reclaimed oil. Their conclusion was to make sure you changed it. Take that info for what you paid for it.
That said, two things to keep in mind: Your truck may have an "extreme duty" PM schedule because you tow or haul (Ford dealer service manager told me even if you tow occasionally). Point two...I have zero doubt oil now is better than its ever been, so I have confidence that it's lubrication capabilities are up to the 5 or 10K mile task. But....that black stuff in oil, that makes it black? That's dirt. It aint food coloring. Contaminants are so named because they aren't supposed to be there. I have historically changed mine in my former sig pic F 150 because I ran the dog pee out of it when towing. It never went past 4000 miles without a change. For the cost of Motorcraft synthetic blend and a new filter, I'll eat the minimal cost difference to keep sleeping soundly at night with the new truck as well. When my odometer in my 7.3 gas engine in my new F-250 hits about 4000 miles, I'll be crawling under it again with my drain pan. Thats my 4 cents. Y'all can do as you wish. The cost of one oil change per year wouldn't make most of us even blink. I'd love to be in that club.
I agree, oil gets beat up pretty bad when towing.
Think about all the heat cycles and pressure it’s put through next time you’re climbing I70 in CO or any big climb!
And with that…..how many people change their transmission fluid regularly. I do my trans every 25-30k miles. When I had the Excursion even the rear diff got new fluid at the same intervals.
I also wonder how many people replace their brake fluid? This is a safety item and when towing (stopping) brake fluid gets very hot! Here again I change the fluid at every brake job, about 30-40k miles. On my class A it gets done about every 3 years.
I have changed the brake fluid and steering fluid several times on our 05 rear diff 13 times and allison external filter every year with the trannie 3 times. might be the reason for the truck running awesomr at 114K miles also new coolant 3 times. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Posted: 03/19/22 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I know this is rv.net. But can we please quit comparing apples and oranges?
“My oil is black after 1000miles…” No chit Sherlock. Mine is black after 10 miles. It’s a diesel. Not a danm thing to do with the OPs post.
“My engine doesn’t get worked too hard towing….” No chit Sherlock. OPs engine isn’t an industrial power plant designed for 500 hr OCIs and 90% duty cycle…. Or whatever it is….I expect the same folks will give me overtly literal responses because I had the facts wrong. I’m only speaking order of magnitude.
Best part is OP is now extending his OCIs!! Lol. And engine will probably outlast the truck!
2017 Heartland Torque T29
bgiroux
Ontario, Canada
Posted: 03/20/22 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you’ve already made up your mind and are just looking for validation. Oil viscosity begins to reduce the minute it’s manufactured. Here’s a comment from the McNally Institute:
Oil that has not been changed for a long time will begin to gel or solidify in an engine, eventually turning into sludge once it has been exposed to the environment. This will result in oil starvation in crankshafts, bearings, camshafts, and other valve train components if the oil is not able to reach all parts of the engine.
Others have said to go by the manufacturers recommendations, which is also good advice.
At the end of the day you can ignore all these comments and do whatever you want because it’s your vehicle and you are the one who has to drive and repair or replace it. Most of us who replace our oil more frequently due so as preventative maintenance because we want our vehicles to last longer without mechanical issues, but you do you. Good luck.
Posted: 03/20/22 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Lol, where’s that guy that used to post here that he’d change his trans fluid after every big road trip? Now that’s some full tilt, hardcore PM!
ktmrfs
Portland, Oregon
Posted: 03/20/22 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I Will be doing he exact same with my brand new 2022 Chevy. It's a turbo truck and I will be changing he oil at 4,000 mile intervals or when the OLM hit's 50%, whichever is first.
Oil is cheap, engine work is NOT.
Thanks!
Jeremiah
I've run one duramax 250K miles following the oil life indicator and still only uses 1/2 qt in 10K miles, and I've run 4 other vehicles over the 200K mile mark following mfg recomended oil and change schedule and again, non more than 1/2 qt between changes and Blackstone lab reports always has come back with high TBN and excellent condition on the oil. Change every 4K if you want but all your doing is paying extra $ to the oil companies.
2011 Keystone Outback 295RE
dodge guy
Bartlett IL
Posted: 03/20/22 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Jeremiah
We’re these all diesels? They have always gone longer on oil changes!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
BenK
SF BayArea
Posted: 03/20/22 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
That CR test with taxis doesn't have one critical cycle of us folks who are not taxis drivers
NY taxis are almost never shut off for more than the time to refuel. In some of those CR reports, there were some who didn't turn off to refuel.
Us non-taxis drivers shut off our engines over might.
That then has moisture drop out vapor to condense inside the engine
Plus the oil film flows off surfaces
To have parts go metal to metal on startup
The why synthetics with better film strength will take longer to flow off
The quality of the filters anti-Drain valve determines how much oil stays in the oil galleries. That helps prevent metal on metal starts
Why more and more oil OEM's are adding molybdenum, which plates metal surfaces
Moly on moly has a VERY low coefficient of friction
Arguable, but many articles report 40%-50%-60% of all wear of an engine
I'm of the opinion of changing engine oil regularly and before the manuals recommendation
-Ben Picture of my rig
specta
utah
Posted: 03/21/22 11:03am Link  |  Quote  |  Print  |  Notify Moderator
After reading every post I've decided to change my oil change intervals.
I'm never going to change my oil and filter again.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
jerem0621
Tennessee
Posted: 03/21/22 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your opinion on this, BenK.
My new 2022 Silverado cost a huge pile of money and I want this gasoline turbo to last for the next 10 plus years. I don’t want to trade or buy another truck.
This little gem will get fresh oil in the crank case often, coolant changes at 30-50k miles( not sure which yet) due to the variable cooling system (the heads and block can be cooled independently via electronically controlled ball valves.) The transmission fluid will be changed at 50% of the recommended interval, and the other fluids will be changed at 50% recommended intervals.
I need this expensive and impressive (to me) machine to last 10 plus years.
I’ve seen sludge in engines and want to do everything possible to prevent that from happening to my machines.
JMHO.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
It’s Kind of Fun to do the Impossible
~Walt Disney~
dodge guy
Bartlett IL
Posted: 03/21/22 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Here is another way of thinking about it!
Why is it when it comes to tow ratings most people say to never push the ratings and to only go 80%! Yet when it comes to maint most people want to push the interval to at or farther than what the manuf recommends.
Just curious!
Page of 8
