canoe on top
Denver, CO, US
What am I missing with the Oxygenics shower head. I got one and didn't care for it at all. Just a narrow stream of water out of the middle of the head. Went back to old style with full circle stream.
ADK Camper
New york
I've made quite a few mods to our camper. One of my favorites is adding three drawers to the under-bed storage area.
![[image]](https://i.imgur.com/DuNe6Nnl.jpg)
This is the finished project.
![[image]](https://i.imgur.com/LRxCaLVl.jpg)
The three drawers are the full extension type. I originally wanted two drawers, but the design of the bed platform used two intermediate stiles which created three obvious spaces to locate three drawers. I added a header above the drawers to reinforce the cabinet and provide support for a false bottom in the storage area above the drawers. I used a handsaw to cut the cabinet openings around the original stiles and the added header. Each drawer is just simple plywood box with a frame made from oval casing molding attached to the front of the drawer. The frame overhangs the drawer to create an overlay on the cabinet opening.
![[image]](https://i.imgur.com/RUSxLWPl.jpg)
This photo shows the bed raised to access the trunk storage above the added drawers.
If you're interested in more photos of my mods you can link to them here.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30197633.cfm
ktmrfs
Portland, Oregon
I also did similar for the underbed storage. Two drawers, and they only went part way back. 1) wanted some full depth, and 2) the space between the front of the bed and the wall was to short to put in full depth drawers. One of the best things we did.
2011 Keystone Outback 295RE
canoe on top
Denver, CO, US
Decided to try the Oxygenics shower head again. Took the old, cheap pressure regulator out of the line. Park pressure pretty low. With the regulator out, the shower head performed much better. Time for a new regulator.
JBarca
Radnor, Ohio, USA
BlackSeriesUS wrote: What's your favorite modification? Did it work out as expected? Or did it flop? Share some pics of your handy work.
There are many, but the "area" that did the most good was, a total running gear/suspension/tire upgrade. It took several projects to complete the entire upgrade and across a few years. But the soundness of everything done, has proven over the years to be "worth it". Below are links to all the RV.net posts, this camper is still going strong and will continue that way for many more years to come.
This upgrade is costly, but if you plan on keeping your camper a good long time, and towing with it, it is worth it. This fits the 10,000# GVWR campers but applies to most any with the stock standard RV suspension/running gear system.
Axle upgrade (5,200# to 6,000# axle tubes) with adjustable axle seats to correct out of alignment wheel locations.
TT axle alignment & install - Detailed (long lot's of pics)
Spring hanger reinforcement to ward off cracked frame web issues.
TT Spring Hanger Stiffening (Long, lots of pics)
Greaseable Bronze spring pin bushing with heavy duty shackles and a rubber equalizer.
Dexter EZ flex upgrade
Adding Monroe gas shock absorbers mounted so they work correctly.
Adding TT Shock Absorbers (Long/lots of pics)
Dexter self adjusting brakes.
Dexter Self Adjusting Brakes (long W/pics and details)
Independent Brake wiring upgrade to no. 10 awg. tinned wire
Independent Brake Wire Feed Upgrade
ST225/75R15 to LT225/75R16 Tire and Trail-aire equalizer Conversion.
ST225/75R15 to LT225/75R16 Conversion
Balancing beads in place of wheel weights to deal with out of balance drums and tires.
Dnya Beads upgrade
LT tire replacements to Bridgestone Duravis R238
LT Tire Replacements - All season
All of the above should come with a new camper as standard, or at least be an option to buy it with them in place. Some brands are getting closer then they use to be to having all of them, but the list is only pertains to a few select brands.
Thanks
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Huntindog
Phoenix AZ
One of many mods. This was in 2000, 3 RVs ago:
4.0 K Onan Microquiet mounted underneath with a 26 gallon stainless steel tank also underneath. Fuel is accessed via 76 Dodge van filler neck mounted between the tounge frame rails with a locking cap. Genset is started with a remote switch and it has a transfer switch, in short it works just like a motorhome.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
deltabravo
Spokane, WA
Keyless entry
Maxxfan with integrated rain hood
C.B.
APPLETON WI USA
1lb Propane Tank Holder
Left over 1" X 6" pine.
4" hole saw.
![[image]](https://lh3.googleusercontent.com/neKbLNvaNM_fwSo0N_D3FUqBfueq3NRPBUwZe03JTnfoLT9PNptUlQZzl8b6U9fggnU9PciCqOAubGmvaOGo0FQPzddKtiihbLE1eOZ3NuVMp83YP7Dr--qrtEH8CtePZBcofircobsToynsTQurXG4zNhWi8QpP46MExjaiuBXFaelwy_oouATSLDyH1CUARvmguUEom4QpSmYkN3vqzJNrVf7Vuqtac1Zm2dpGTHeiFBFD0m1Fto9Pd9fw1n6wRzGCzaJRCAhP_Ioh84dzzvtqQJvBIbsUrjtvybtkzSUFVJlxM8ovrPbzdFi9Da8yxNs04zasvmR-9LHP7t02UWEY1v_gARmMiv8N_ByuGM8nOIvOkZJHiG9ehI0cWGS54-mZXZ9_BgcOovMCeFPURivmsj-esm4BEeUfy-afCE9WukGXBXBXyAV1-_f5I5hFuYRghXBcB3_tsFb1vLnHJbnyQpRgfVCjlkCvpvcW9Pavbi00ohDGZa1247rm19E8xhavZPGc8wESyk6ZLNEAGDcHPcb6PWEAUPaLBnXwJhkj3xPYav5PT8ra3YaZJyTS6knaglOgftxVMP3qXfhxCbUeLfyuhxntC5IpESfJ_EInb5I6Kn7fscJJpb-QPVJxlbc0cMIruWN33Qeb0sk7mDpHJXkffXGioUh7HPpctum21TlWojCqltxYYEwQCL9e--hdVsI_ZpC_SJHazU0YfHtUcH1jJXNqgSA-cu7QRfKeDjY9Q3hHX6tKrnk=w800-h600-no?authuser=0)
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
C.B.
APPLETON WI USA
ADK Camper wrote: I've made quite a few mods to our camper. One of my favorites is adding three drawers to the under-bed storage area.
Great job!
Little to cold out in shed!!!
When we get warmer weather rest assured I'll try copying your work.
C.B.
Bears Den
Estero, Fl.
OxygenIcs shower head, mattress, LED lights inside TT, Solid Step and Maxxis tires. Love em all.
edited 03/26/22 08:53pm by Bears Den *
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
