RV.Net Open Roads Forum: Travel Trailers: Modifications
BlackSeriesUS
City of Industry
Posted: 03/16/22 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
What's your favorite modification? Did it work out as expected? Or did it flop? Share some pics of your handy work.
ken56
Tennessee
Posted: 03/16/22 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
It may not sound like much but I added 2 shelves in the pantry. There was so much room between the 3 shelves that were in there that I was able to put in 2 more. Just the right height for canned goods. The wife loves it. Another was I divided the under bed storage in half. We have a cat and one half is where the cat box goes. Works very well actually. I also added a wire basket in the bathroom for towel storage. Up behind the toilet high enough not to be a head banger. That works quite well also. Just small things that make RV life easier. Sorry about no pics though.
Southern California :(
Posted: 03/16/22 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Solar…before “solar prep” was an option and skeptics were saying solar doesn’t work and you’ll see panels all over the roadway.
BarabooBob
Baraboo, WI
Posted: 03/16/22 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
When we buy a new trailer, my wife has visions of what shelves and dividers she wants inside the cabinets. After she describes them, I build close to what she wants. All of my shelves have the weight carried by the floor, not the sides of cabinets because the cabinets are built very cheaply.
Our Class C went over 50,000 miles with my mods, first TT went 10,000 (sold at that point) and our current TT has gone 25,000 miles without anything coming loose.
I also remove some of the plywood panels that builders install to hid the plumbing, I redo to areas so that I get extra storage and still looks good.
I add a second LP tank and auto switch over regulaotr. I hate getting up in the middle of the night to change LP tanks.
One other thing we do is cut the bench seat plywood lids in half and mount them on hinges to make it easier to get stuff out of the seat. Some extra framing is required to keep the seats strong.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
dodge guy
Bartlett IL
Posted: 03/16/22 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Dexter EX Flex with wet bolts.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 03/16/22 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
The DF likes to load all of the drawers very heavy which causes them to fly open on the bumps or sharp corners. This means newer heavier door latches.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
afidel
Cleveland
Posted: 03/16/22 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
Progressive EMS install is the first mod I've done to both my trailers.
Upgraded thermostat the second.
On the current trailer the shelf in the pantry over the TV collapsed on the first trip because they constructed it like idiots (floor UNDER the styles stapled upwards?!?) So I cut 2 pieces of 3/4 plywood to replace the luan floor, it's worked very well even with the earthquake that is Michigan roads.
We've cut out Reflectix to the size of the windows, helps a ton with retaining heat in the winter and blocks enough light for the boys to sleep in the rear living area despite it being about 60% windows.
We installed a wire rack shelving unit in the space between the shower and the hall wall, gives us a linen closet like space so we can use the hall closet for the boys. It tipped over once so I tied it off to the bathrobe hanger and that's worked well, just needed to stop the tipping from getting started.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
LynnandCarol
Rockport, TX
Posted: 03/17/22 06:58am Link  |  Quote  |  Print  |  Notify Moderator
We installed Reflectix in every closet and cabinets touching the outside walls. Installation was done with a staple gun. This additional insulation helps with cooling and heating. We could tell a difference right away!
deltabravo
Spokane, WA
Posted: 03/17/22 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Adding more USB ports.
Bluetooth T-stat upgrade
* This post was edited 03/26/22 05:43am by deltabravo *
C.B.
APPLETON WI USA
Posted: 03/17/22 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Wife wanted tissue box next to bed. Tissue box kept falling off the
shelf.
Added to the shelf. Now box stays in place and tissue can be pulled out up or down.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
