I do not know if the I-pad can read the phone's GPS however
Can you get a GPS Dongle for the I-Pad. most of them are designed to plug into USB-2 or 3 but you might be able to find one for the pad. This will be WIRED however (plugs in) I have one for a radio I use that I've yet to install (Need better weather and a few parts) Once that's done my radio will know where it is all the time... (some of them do now but this is the one in my car so it moves)
If the pad has a standard USB port look at the Garmin GPS-18X The one I have does NOT have a USB connector but they make it with.
dryfly
wa8yxm wrote: I do not know if the I-pad can read the phone's GPS however
I am not that familiar with the iPad but I don't think the port on the iPad is a standard USB 2 or 3 port. Maybe someone will correct me if I'm wrong. I bet if it were possible there would be lots of info out there, and of yet I have found none.
I did a quick look at the Garmin 18X and it appears it is for interfacing with a computer. Since I have other GPS devices to rely on, I'm not that interested in spending a lot of time or money, but just wondered if the phone and pad might work together. It's looking like it's a no go.
The necessary Adapter to plug in a USB device like the Microsoft Dongle I have
I'd offer you the MIcrosoft dongle free if I knew where it is.
The Garmin GPS-18X with USB plug hower is likely much better "Dongle" I'm not getting rid of that one. NO way.. (I hope to install it in a week or 2)
time2roll
Jackathan wrote: Wifi only iPads do not contain the GPS hardware to allow them to act as a standalone GPS. The OP is wanting to know if the iPhone can somehow share it's GPS info with the iPad. I don't believe simply using the iPhone as a hotspot will work for that. It would be easy to test, though. Does the iPone actually use GPS satellite signals direct? I thought phones used the cell tower position to geolocate the phone.
675w Solar pictures back up
fyrflie
Martinez, CA. USA
I have a slightly different setup than what you are asking. I use a Garmin GPS receiver and connect it to my iPad via Bluetooth. Then use any navigation program you want. I get the large, easy to read screen and great useable features without relying on cell service.
I have read that an iPad with cell capability has the gps chip built in. And you do not have to pay for an extra phone number.
But to answer your question, I have not tried to connect my iPhone to my iPad for navigation. Only for hotspot use while camping.
Good luck.
fyrflie
Martinez, CA. USA
dryfly wrote: I recently got a wifi only (non-cellular) iPad. Is there a way to tether the iPad to an iPhone to enable using it as a GPS device?
Just found this after I posted my response.
“AirLocation is an iOS app that sends GPS data from your iPhone to your Wi-Fi-only iPad. To use it, you activate the Personal Hotspot on the iPhone, connect the iPad to the hotspot and run the app on both devices. Now you can use proper, accurate GPS data to track yourself on the iPad's large screen.”
https://www.wired.com/2011/04/airlocation-sends-gps-data-from-iphone-to-ipad/
I couldn’t find the actual app anywhere but it did lead me to numerous other posts both on the internet and YouTube about how to accomplish what your trying to do.
Hope this helps.
edited 03/20/22 10:03am by fyrflie *
dryfly
fyrflie wrote: dryfly wrote: I recently got a wifi only (non-cellular) iPad. Is there a way to tether the iPad to an iPhone to enable using it as a GPS device?
Hope this helps.
That sounds like the solution, but as you say the app is nowhere to be found. I'm surprised there are not more apps like that out there. I'll do some more searching and look for the posts you mention. Thanks.
1492
Arlington, VA
You never mentioned what version of the iPad you acquired?
A more straightforward solution may be to just sell your present iPad on Ebay, and get a used WiFi/Cellular model? A list of iPads compatible with latest iPadOS is available here. Some available under $200.
If you're using it primarily as GPS, and don't need the current features supported in the most recent iPadOS, then a few are available for less than $100. that support version 12. Check the GPS app you want to use, though many popular ones still support iOS/iPadOS 12 and up.
gkainz
Arvada, CO, USA
I plugged in a Bad Elf gps on my non-cellular iPad mini for an aviation GPS nav unit. Worked just fine.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
