TNGW1500SE
Oliver Springs TN
I have a 2020 transit 250. I just installed a set of new trailer electric brakes on my 12x6 cargo trailer. Somewhere around 2K pounds. I got them off Amazon. The brand is Southwest Wheel 3,500 lbs. Trailer Axle Electric Brake Kit. It's a magnetic drum kit.
I also installed a Tekonsha 90195 P3 Electronic Brake Controller. I hooked the controller up to the CCP connector and grounded it between the seats at the factory ground. Got a brake signal off the connector at the brake pedal using the far left connector. Ran a wire all the way back to the new 7 pin connector.
It works but barely. You can feel the brakes a little bit if you move the lever when the controller is set on 14 (Max) with the boost set to 3 (high). If I pull the lever all the way the controller reads up to 13.5. It does apply power to the brakes (like it should) when I apply the vans brakes as well. I adjusted the brakes before I drove it the first time and then again after driving. I turned the adjuster until the wheel wouldn't turn and backed it off a few clicks just until it had a very little drag. Set on 14 with the boost on 3 it will barely kick in the brakes and will not lock up even in gravel. Everything is new.
UPDATE: Measured voltage at the trailer. 10.43 volts when the lever is pulled to max
edited 03/18/22 12:58pm by TNGW1500SE *
BenK
SF BayArea
Guessing ground wire and the run to the trailer via sheetmetal to receiver, to shank, to ball, to trailer coupler, to trailer frame, to axle (via leaf spring mounting hardware), to the backing plate and finally to the magnet
You may have full voltage, but with that path, it will NOT carry much or enough current
If that is the case, then run a dedicated ground wire directly from the controller to the trailer brake magnet wire. Of course some connectors, but chose low impedance connectors.
Also, use a large gauge wire
-Ben Picture of my rig
TNGW1500SE
Oliver Springs TN
Both brakes are grounded with 14 gauge wire ran to 7 pin. All connections are soldered and covered in heatshrink tubing.
edited 03/19/22 07:45am by an administrator/moderator *
TNGW1500SE
Oliver Springs TN
The people who sold me the brakes want me to do this:
https://lci-support-doc.s3.amazonaws.com........ets/axles-and-suspension/ccd-0001947.pdf
UPDATE. THAT FIXED IT.
edited 03/18/22 03:27pm by TNGW1500SE *
BurbMan
Indianapolis, IN
Yup, you have to get the magnets seated so they make good contact. Glad you got it worked out!
TNGW1500SE
Oliver Springs TN
UPDATE!
My trailer axle is now bent!
After doing the procedure that they recommended, I noticed now that my drivers side wheel on the trailer is not in line with the trailer anymore. It's really towed out bad. Even my wife noticed it. Now I will have to replace the axle. The wheel bearings are fine. I never hit anything during the "break the axle procedure" they recommended. It bent the spindle (that is part of the axle and not replaceable). It's a drop axle design. The instructions said not to use the vehicle brakes and use the trailer brakes to slow the van. That's what I did and now........... Well,,, that must not be the best idea!!! It must have been a cheap junk axle to begin with. On the bright side,,,, guess I should be glad it happened now where I'm home with the tools to replace it. Northern Tools sells replacements. Anybody know if they're any good????
deltabravo
Spokane, WA
BenK wrote: If that is the case, then run a dedicated ground wire directly from the controller to the trailer brake magnet wire. Of course some connectors, but chose low impedance connectors.
The purpose of the ground wire on the trailer brake controller is just to provide a B- connection so the controller will power on.
The controller doesn't need to have its ground wire routed all the way back to the brake magnets. THe 7 pin plug on the van will have a trailer ground wire, as will the trailer end of the 7 way cord.
deltabravo
Spokane, WA
TNGW1500SE wrote: After doing the procedure that they recommended, I noticed now that my drivers side wheel on the trailer is not in line with the trailer anymore. It's really towed out bad. Even my wife noticed it.
I can't see how applying the trailer brakes would bend a spindle.
If that was a true scenario, you'd hear about a lot more bent axles.
Get a Dexter axle.
JRscooby
Indepmo
deltabravo wrote: TNGW1500SE wrote: After doing the procedure that they recommended, I noticed now that my drivers side wheel on the trailer is not in line with the trailer anymore. It's really towed out bad. Even my wife noticed it.
Get a Dexter axle.
I don't know about your or the OP's area, but in much of the country, this time of year, potholes are pretty common. Hitting 1, with brake pressure fairly high can do a lot of damage. If a axle is loaded close to capacity can be a pretty big hammer.
RAS43
Littleton,CO
Get a Dexter axle.
Take the trailer to a commercial trailer repair shop and they should be able to straighten the axle and align both. I have had that done on 2 trailers.
