jjrbus
FT Myers FL
I am ready to put a box on my new to me 2002 Roadtrek for a Honda 2000 generator. I have used the Honda on RV's for years and am happy with them. I also have installed a LG 9500 inverter AC which runs very well with the Honda 2000.
I have also built several box's for Hondas on my RV's over the years including 2 that were sound box's.
The box's look like box's on the rear. Has anyone seen anything creative, artsy or neat looking, other than a diamond plate box on the rear?? I have looked all over the net and see nothing.
Cambria, California area
Provided tongue weight is adequate and rack is reenforced, looks pretty good to me.
bgum
South Louisiana
We have a Airstream Bambi and carry our Westinghouse igen2500 on the tongue. Between the propane tanks and the trailer. Total additional weight is about 11 pounds as we removed one of the propane tanks and that is where we carry a small gas container. It is above the battery but the top is no higher than the propane tank cover. Weather is not an issue. Nor is vibration or carbon emissions. Works for us.
edited 03/20/22 09:50am by bgum *
That AS mod looks good.
pianotuna
Regina, SK, Canada
Hi,
My Yamaha generator lives in a yellow cage made from expanded metal on the back of the Class C motorhome.
Regards, Don
jjrbus
FT Myers FL
I am disappointed, thought I might get a bit of input. Best I can come up with is paint the box the same color as the RV so it does not look so industrial.
pianotuna
Regina, SK, Canada
jjrbus,
I used the cage because I wished to run the generator while trundling down the road.
It is painted bright yellow to make it visible to other drivers.
Boscorelli
CT
It's a niche market. You won't find many choices. What you want is custom work and it will be pricey.
jjrbus
FT Myers FL
pianotuna wrote: jjrbus,
I run mine while driving!
jjrbus
FT Myers FL
Boscorelli wrote: It's a niche market. You won't find many choices. What you want is custom work and it will be pricey.
Not only are they grossly over priced, some are horrible designs! My RV is my hobby I will design and build my own, it will be a sound deadening box and should cost between $300 to $400 in material.
