RV.Net Open Roads Forum: Fifth-Wheels: Can you jump your 5’er with your truck?
 > Can you jump your 5’er with your truck?
Roger10378
Goodrich, MI.
Posted: 03/20/22 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Very few if any 5er's use 6 volts. They may have 2 6 volt batteries wire in series to give 12 volts but nothing in them runs on 6 volts. you would need to jump 12 volt to 12 volt.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Mondooker
Florida Gulf Coast
Posted: 03/20/22 10:09am Link  |  Quote  |  Print  |  Notify Moderator
My unit has two 6 volt batteries, four 6 volt batteries actually. Hopefully the solar will keep the batteries up? But great to know the truck batteries could be used if necessary.
Thanks guys
bob213
Fresno, CA
Posted: 03/20/22 11:03am Link  |  Quote  |  Print  |  Notify Moderator
It takes two 6v batteries wired in series to make a 12v. If you were to jump them you need to connect one cable to each battery NOT both cables to one.
jdc1
Rescue, Ca
Posted: 03/20/22 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
jdc1 wrote:
To maybe pull in a slide or raise the jacks? Why not? But, your cables are going to get REAL hot.
Hot? Running jacks?
That's 25 foot of cable that'll be needed. You should see how hot my in bed transfer pump cables would get....and they were only 12' long.
6X2=12volt
time2roll
Posted: 03/20/22 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Together it is one big 12v battery. Connect on the right terminals and all will work fine.
675w Solar pictures back up
Bionic Man
Colorado
Posted: 03/20/22 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Why are you wanting to “jump” the trailer? If you are concerned about slides and jacks with dead trailer batteries you could plug trailer umbilical cord into the truck (with truck running) and have enough power to use the jacks and pull in the slides.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Mondooker
Florida Gulf Coast
Posted: 03/20/22 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I DID NOT KNOW THAT!
2oldman
NM
Posted: 03/20/22 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
I guess so, but that doesn't jibe with the comment above about how cables will get hot. Hot comes from a lot of amps. Umbilicals don't carry a lot of amps.
Veebyes
Posted: 03/20/22 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
If the trailer battery bank is low, for whatever reason, plug into the truck as per usual & run the truck as fast idle for a bit before trying heavy draw things like slides.
2007 Alpenlite 34RLR
fj12ryder
Platte City, MO
Posted: 03/20/22 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've checked the amp draw on my Momentum when running the slides in/out, and it pulls 65 amps. Yeah, I think those jumper cables will get pretty warm. [emoticon] If those trailer batteries are way down, you will be pulling some pretty high amps.
Howard and Peggy
"Don't Panic"
