RV.Net Open Roads Forum: Fifth-Wheels: Can you jump your 5’er with your truck?
 > Can you jump your 5’er with your truck?
pyoung47
MO
Posted: 03/20/22 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve never done it, but I carry two sets of cables for that eventuality.
Bionic Man
Colorado
Posted: 03/20/22 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Bionic Man wrote:
If you are concerned about slides and jacks with dead trailer batteries you could plug trailer umbilical cord into the truck (with truck running) and have enough power to use the jacks and pull in the slides.
I guess so, but that doesn't jibe with the comment above about how cables will get hot. Hot comes from a lot of amps. Umbilicals don't carry a lot of amps.
All I can tell you is that I've needed to do it with my trailer, and it works for me.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
valhalla360
No paticular place.
Posted: 03/21/22 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Mondooker wrote:
My unit has two 6 volt batteries, four 6 volt batteries actually. Hopefully the solar will keep the batteries up? But great to know the truck batteries could be used if necessary.
Thanks guys
Don't try jumping if you don't understand the difference between a 6v system and 6v batteries wired to produce 12v.
But yes, you can power your RV 12v system by connecting into the truck battery:
- Leave the truck running, so you don't wind up with a dead truck battery (don't do this for long periods).
- You aren't "jumping" as that implies starting an engine...or using a big ramp to leap your truck over the top of the 5er (take a video if that's what you meant).
Google 6v batteries wired for 12v and make sure you fully understand how they are wired and where you would connect before trying it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
schlep1967
Harrisburg, PA
Posted: 03/21/22 06:24am Link  |  Quote  |  Print  |  Notify Moderator
It's funny that people think heavy gauge jumper cables are going to get hot. Look at the wires going into the landing gear motor. Not exactly heavy wiring.
I had switch problems on my landing gear. I used my jumper cables that are 20 foot of 4 gauge wire. I clamped directly to the wires coming off the motor. The landing gear motor runs much faster when using the jumper cables than it ever did using the factory wiring.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
2oldman
NM
Posted: 03/21/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, that is strange. They're designed for hundreds of amps. The clamps that connect to the batteries may get hot, over time, and transfer that heat to the cable.
* This post was edited 03/21/22 10:06am by 2oldman *
dedmiston
Coast to Coast
Posted: 03/21/22 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I've done it tons of times over the years. It's the #1 reason that I always unhitch from the truck (so I can turn the truck around to jump the gen if I need to). I don't really worry about it anymore with solar, but it's still a habit for me.
Keep in mind that you want to jump from the truck to the gen, not to your trailer batteries. If you have a large battery bank, it will take too long for the batteries to charge up enough to crank the gen. But you can connect directly to the hot side of the gen and the ground, and then it cranks right up.
It's always a shameful moment when you have to jump like this, but it happens a couple times a year in our groups (not to the same person though).
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
joebedford
Soon heading south for 1st time in 3 years
Posted: 03/21/22 10:53am Link  |  Quote  |  Print  |  Notify Moderator
I've had to do it both ways: jump the trailer from the truck when the battery ran down overnight from the furnace; jump the truck from the trailer (actually I started the generator and plugged in my battery charger to the trailer).
strikeu
Bama
Posted: 03/24/22 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
I was always under the impression that you get all the power you need from the 7 pin to charge batteries or use 12V for any purpose. is that not correct?
2018 RAM 3500 DRW 6.7L Cummins (daily driver RAM 2500 same engine)
2017 Forest River Crusader
1 wife, 2 Cats
Fly Navy
Veebyes
Posted: 03/24/22 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone figured out the take off ramp angle & the speed needed yet?
2007 Alpenlite 34RLR
pianotuna
Regina, SK, Canada
Posted: 03/24/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
strikeu,
It is rare that the 7 pin provides decent voltage to charge the house batteries.
One reason is length of wire and that causes voltage drop. The wire needs to be beefed up.
The best solution may be a dc to DC charger placed in the line. Placed near the house bank--but not in the same compartment.
Regards, Don
