chevyman94
MD
Hey guys I have a diesel 2022 Silverado 3500 High Country the crew with a 8 foot bed. I have my toolbox semi installed for a 60 x 10 x 19 tank at most right now to go under the tonneau cover I have on it and behind the box.
My uncle has a 2014 GMC 3500 crew 8 foot bed with a gravity fed system with a shut off valve.
Which system would you use and why also any recommendations in advance on what electronic fuel pump systems.
I am leaning towards the electronic as I have 5 up-fitter switches in my cab and would like to use them. My uncle likes the kis system
edited 03/24/22 10:38am by chevyman94 *
Cambria, California area
Aren’t gravity fed gasoline tanks illegal?
Flashman
Tucson, Aizona, USA
Lwiddis wrote: Aren’t gravity fed gasoline tanks illegal?
Diesel?
chevyman94
MD
It is a diesel and no they aren’t illegal
hornet28
Muskegon Mi.
A simple electric fuel pump and a light or buzzer in the cab as a reminder to shut the pump off. I did one for my brother that way. I put a flashing LED in the dash for when the pump was on
chevyman94
MD
hornet28 wrote: A simple electric fuel pump and a light or buzzer in the cab as a reminder to shut the pump off. I did one for my brother that way. I put a flashing LED in the dash for when the pump was on
Any recommendations on a pump set up such as a brand?
we3
Birnamwood Wi.
I have several and I prefer a completely isolated system. I have a 4 hour bladder so stopping to spend 6 minutes to transfer fuel is no problem. The greatest advantage for me is it can be completely removed to haul large loads or place in a different truck.
Aren’t you trying to start an argument, or just typical passive aggressive response?
2017 Heartland Torque T29
chevyman94 wrote: hornet28 wrote: A simple electric fuel pump and a light or buzzer in the cab as a reminder to shut the pump off. I did one for my brother that way. I put a flashing LED in the dash for when the pump was on
Go read the other thread just started on this in Tech I believe. All different options discussed.
You’re looking for an “excuse” to use switches in your truck?? Lol
Not certain why you’d need to pump the fuel since gravity works.
Keep it simple and best application for your use.
edited 03/24/22 08:54am by Grit dog *
hornet28
Muskegon Mi.
Nothing complicated or expensive. Here's one https://www.amazon.com/Electric-Transfer-Universal-Pressure-2-5-4psi/dp/B07JPDZC4M
