RV.Net Open Roads Forum: Auxiliary fuel tank and gravity vs electronic pump
Search only in Tow Vehicles
 > Auxiliary fuel tank and gravity vs electronic pump
dedmiston
Coast to Coast
Administrator
Posted: 03/24/22 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Lwiddis wrote:
Aren’t gravity fed gasoline tanks illegal?
Aren’t you trying to start an argument, or just typical passive aggressive response?
It's just Lwiddis being Lwiddis.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
JRscooby
Indepmo
Posted: 03/24/22 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Sorry. I do not see anything in the OP that tells what fuel the pickup uses.
And it is a fact there are a lot of regulations, (impact protection, vaper recovery, whatever) that apply to gasoline tanks in vehicles. Most tanks sold to mount in bed are advertised diesel only to avoid the regulation.
For many, is it legal is a valid question.
Of topic, but kinda funny.
Contractor I did a lot of work for had a few weeks work, about 60 miles from home. I decided to leave 3 trucks on site, just sneak 1 into town every day for fuel. Contractor could not fuel all equipment on job with the transfer tank mounted on his truck, so we strapped a tank down in my tool truck.
One morning, I ran into a DOT check on my way in. When stopped, had 3 things on my mind; 1, likely over my licensed weight limit. 2, real close to limit on licensed distance from home. And 3, the straps holding that tank did not have a load limit label. LEOs 2nd question, behind DL, registration, and insurance, was "What kind of fuel in tank?" Now I'm not thinking about the step by his knees when I said "Dyed, off road diesel" He was mad when he stuck his wand in my gas tank, and the plastic dissolved. At the time I had a 460 in that old F500.
Sport45
Not far enough from Houston, TX
Posted: 03/24/22 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Mine’s gravity feed. If I leave the valve open I can drive almost 900 miles before the fuel gauge in the dash starts moving. The in-bed tank has a level gauge but I never look at it.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
thomas201
Eastern Panhandle WV
Posted: 03/25/22 07:30am Link  |  Quote  |  Print  |  Notify Moderator
When I had diesel, I used gravity feed. With gas, I have to pump. I would not pump diesel, because if you leave the pump on it will have to go somewhere after the truck tank is full. So, if you pump, you need a return line to the deck tank. Just saying.
hornet28
Muskegon Mi.
Posted: 03/25/22 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Diesel or gas you overfill the tank it's going somewhere. A return line isn't needed. The trick is to have a reminder such as a buzzer or light in the cab to remind you the pump is on. If one of those doesn't do the trick well, "You Can't Fix Stupid"
chevyman94
MD
Posted: 03/25/22 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone for your input, I went with a Lund 37 gallon steel tank and a gravity fed system with a shutoff valve for over flow! It would have been cool to utilize my upfitter switches but I’ll probably use them for the light bar and winch set up I’ll be doing later
JRscooby
Indepmo
Posted: 03/25/22 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'm hard of understanding here. If you have a line from 1 tank down to another, the fuel will flow. And if the level of fuel is above the fill neck of the lower tank, or any vent, what will stop fuel from coming out the vent?
Just drinking bleach here; Does the pump in tank send more fuel to injector pump then the engine will use, then extra returned to tank? If so, put a tee in the supply line between tank and injector pump. (or filter) On the leg of the tee that goes to factory tank put a normally open solenoid valve. The side going to engine, no change. The other leg, a check valve strong enough to hold against factory pump pressure. Have the pump by add-on tank feed thru the check valve. A switch on dash cuts power to factory pump, closes the valve in supply line, turns on added pump, and a light near fuel gauge. Fuel would feed thru check valve to engine, and the extra returned to OEM tank. As you drive the fuel level shown on factory gauge would rise, near full, switch back to OEM function
Sport45
Posted: 03/25/22 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Mine has a float valve where it ties into the main tank fuel fill line. It doesn’t let any diesel in once the tank is full. I suppose it’s similar to the valve that stops water flow once your toilet tank is full.
hotpepperkid
Kingman AZ
Posted: 03/25/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I want to hear the rest of the story.
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
JRscooby
Indepmo
Posted: 03/25/22 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I can see how that would work. OTOH, the valve in toilet starts to leak, water drains thru the overflow, overfills bowl, and down drain. Can waste a lot of water but that is the only harm unless you have to pay a plumber to replace it.
A similar system is the float/needle seat system in a carburetor. When that leaks gas can get on top of engine, but it also dumps into the engine stops it from running right (if at all). Fuel pump stops putting gas to carb. Fire is a possibility, but most likely expense is carb rebuild.
What happens if you park the truck with a leaking float valve.
BTW, in my lifetime I have replaced over 100 toilet tank valves, and rebuilt even more carburetors. Failure is not a far-fetched idea.
In that area, most of the owners of small farms have some kind of job in town. We where on a main road into metro area, where the farmers likely to pass by commuting.
Most of the farmer have tanks set up, get fuel delivered for use in ag equipment. The sellers of that fuel do not collect the road taxes, so the fuel is cheaper. But to mark the fuel as non-taxed, the sellers are required to add dye to the fuel. A percentage of the farmers pump the dyed fuel in pickups. So on occasion the state tax collectors join the other LEOs and sample fuel as part of safety inspection.
As for my other infractions? MFIC told me to be right next trip thru. Rode home with other hands, used some chain and boomers to mount another transfer tank to a utility trailer, hauled it back and forth with my El Camino.
