jjj
Lancaster,Ca.U.S.A.
I just saw these today. They have been out for years and never seen them. I was wondering if anyone has used these and what your thoughts are about them. They say they can be used to store your trailer with the wheels off the ground.I want to use them to lift my fiver. Www.trailerlegs.com
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
Owens River area
Does your 5er manufacturer approve of lifting RV off the ground for extended periods via the frame at the leg contact points? The tires, rims, axles and where attached to the frame were built to support the RV for years and years without a break.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
way2roll
Wilmington NC
Seems like a pretty expensive solution to a problem that doesn't exist.
Tyler0215
Iowa
It looks like they would be hard to get in place to raise the trailer. If one would slip and not rotate with the others you would have to start over.
What's the reason to use them at all?
way2roll
Wilmington NC
Why do you want to lift your FW? Couldn't you use your jacks?
jjj
Lancaster,Ca.U.S.A.
To raise tires of the ground for long storage times.
fj12ryder
Platte City, MO
Thanks, but no thanks. Look like more trouble than they're worth.
edited 03/26/22 08:01am by fj12ryder *
Howard and Peggy
"Don't Panic"
joelc
Cedar Point, NC
Unless you have hydraulic jacks the only way I can see this being done is to manually jack up each side of your trailer and use cement blocks under load points. On the other hand, I live in my Camer 5er 7/360 and the tires are still on the ground, but I do have the leveling jacks taking some weight off them. What I would recommend is take some plastic table place mats and put them under each tire (bring your RV over them) separating the ground from the tire. This will prevent leaching tire chemicals to the ground. I do this while camping also. In addition cover the tires or keep clean and spray some tire Shine on them to protect the sidewalls from UV.
TXiceman
Full Time RVer
Looks like a solution looking for a problem to solve. A total waste of time and money in my opinion.
Ken
Amateur Radio Operator.
way2roll
Wilmington NC
jjj wrote: To raise tires of the ground for long storage times.
I think you're borrowing trouble. I either use my jacks to keep the tires off the ground or just park on boards. Sun and lack of use ages RV tires more than anything else. For the cost of these devices you could buy new tires which are going to age about the same rate whether they're on the ground or not.
