RV.Net Open Roads Forum: Fifth-Wheels: Trailer Legs
 > Trailer Legs
TXiceman
Full Time RVer
Posted: 03/28/22 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Another issue I see is that the axle manufacturers say not to place jacks on the axle tube as it may damage the axle. These lift the axle exactly where the manufacturers tell you not to lift the trailer.
Ken
Amateur Radio Operator.
Cummins12V98
on the road
Posted: 03/28/22 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
EXACTLY!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
CapriRacer
Somewhere in the US
Posted: 03/29/22 06:27am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
..... Not sure this nylon wrap would cause flat spotting. ....
Yes, that is what I am referring to - and there are some circumstances where the tires will flatspot. It isn't a 100% thing.
MFL wrote:
...... My Providers never seemed to flat spot from sitting over Winter. I do add an extra 5 psi in late fall due to air loss from Winter temp extremes. I air to 70 psi, even though tire max is 65. I let back down to 65 when warm temps return.
We do know the nylon tires of yesteryear did flat spot.
Jerry
Yes, that is what I am talking about. Adding that 5 psi would certainly help prevent the flatspotting. Plus, flatspots can be small enough not to be noticeable. (I'm sure that a flatspot that would lightly shake the stuff in a trailer's cabinets is not enough to be noticeable from the tow vehicle.
CapriRacer
Visit my web site: www.BarrysTireTech.com
valhalla360
No paticular place.
Posted: 03/30/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
CapriRacer wrote:
valhalla360 wrote:
jjj wrote:
To raise tires of the ground for long storage times.
Why do you want to do that? Modern tires are fine sitting for long periods.
No, they aren't!
Many tires today have cap plies made of nylon. Nylon is VERY prone to flatspotting - and the longer they sit, the more likely the flatspots may be permanent.
I believe you are thinking of tires from 40-50yrs ago.
Modern tires, it's simply not a concern.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > Trailer Legs
