RV.Net Open Roads Forum: Tech Issues: Rear/ bunk ladder
 > Rear/ bunk ladder
GoingCrazyInCali
California
Posted: 03/26/22 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1990 tioga motorhome. The bunk ladder is attached to the rear ladder for roof access and I can't get them a part. It's just a plastic cap that holds the two pieces together, but it's really stuck! Any suggestions?
LittleBill
Scranton, PA USA
Posted: 03/26/22 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
hair dryer?
GoingCrazyInCali
California
Posted: 03/26/22 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Tried that, but I'm willing to try again. Thank you.
LittleBill
Scranton, PA USA
Posted: 03/26/22 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
use a heatgun? wrap the metal in ice water towels, and just heat the plastic?
Y-Guy
Tri-Cities, WA
Posted: 03/27/22 08:21am Link  |  Quote  |  Print  |  Notify Moderator
If you have a water heater where you can tap into the drain valve try hooking up a hose there and using the hot water - it's good to get the sediments out anyway but the hot water may do better.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
Seattle Steve
Tucson
Posted: 03/27/22 09:41am Link  |  Quote  |  Print  |  Notify Moderator
After 30 years in the sun it's possible the plastic has gotten dried out and too brittle to flex at all. Keep trying, but don't be too disappointed if it breaks, because that might be the only way anyway. There's always heavy duty velcro to hold it in place.
dougrainer
Carrolton, Texas
Posted: 03/27/22 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Can you post a Pic? I have 43 years as a RV tech and I have NEVER! seen a inside bunk ladder ever attached to the exterior roof top ladder from the factory. It is possible that in 30 years, a previous owner attached that ladder to free up space. Doug
4x4van
California
Posted: 03/29/22 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
Can you post a Pic? I have 43 years as a RV tech and I have NEVER! seen a inside bunk ladder ever attached to the exterior roof top ladder from the factory. Doug
Same here; something doesn't make any sense.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
GoingCrazyInCali
California
Posted: 03/29/22 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
I will get an actual picture of the ladder as soon as I can, but for now, here is a page from the owners manual explaining how to put up the rear ladder.
https://www.manualslib.com/manual/864006/Fleetwood-Tioga-Montara-1994.html?page=22
dougrainer
Carrolton, Texas
Posted: 03/30/22 09:29am Link  |  Quote  |  Print  |  Notify Moderator
You are comparing apples and oranges. YOU stated Bunk Ladder on rear exterior roof ladder. The link shows when the RV has a removable exterior ladder that is stored INSIDE the storage and then is installed on the exterior mounts. AND you have a 4 year older RV than the manual you stated. Bunk Ladders are usually short straight ladders that help get into the front overhead bed above the drivers seats. THAT type ladder is normally stored by lifting up that bunk mattress and laying underneath it. Doug
 > Rear/ bunk ladder
