Busdriver
Shepherdsville Ky 40165
Have a 2019 Duramax , have a service exhaust soon message check manual. The manual says contact dealer. Anyone have any ideas. Don’t seem to have any power.
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
jdc1
Rescue, Ca
You need a scanner to tell what the problem is. Sounds like you went into limp mode, to keep from blowing something up.
#1Flyboy
California
U might try googling “ Duramax Forums “……
If I had a truck with Tier IV emissions, I would not leave home without a good code reader. Something like AlfaOBD or similar.
2017 Heartland Torque T29
Michelle.S
Western NY till fall, then Sebring, FL
Many Auto Parts Stores can read the code and give suggestions. Might be something simple or major, but the code will help.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
ksss
Eastern Idaho
It should have at least basic Onstar. It will tell you what the code is.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
ACZL
UPstate,NY
Based on OP's post, I'd place $$ that the DPF (Diesel Particulate Filter) is plugged up
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Cummins12V98
on the road
Auto Parts can look at your codes.
Curious do you do a lot of short trips?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
sayoung
Tx
ACZL wrote: Based on OP's post, I'd place $$ that the DPF (Diesel Particulate Filter) is plugged up
There is also 2 oxygen sensors , one on each side of the DPF filter if like my 2012.
This is one of those "makes ya wonder" threads. OP posts a rather basic/cryptic post asking for help/suggestions, then doesn't return, even though it appears to be an immediate type of issue.
Could be....
DEF injector
DEF pump
DPF or SCR plugged
Malfunctioning sensor on exhaust, EGTs or O2s
Bad DEF sensor or bad DEF
Drives like an old man and plugged 'er up and hasn't spent any time completing a regen.
Physical issue with DFP or SCR
These off the top of my head. Bout as good as suggestions as can be given with literally no additional info provided by the guy with the constipated exhaust!
