2002 Roadtrek 200 on Chevy 3500 chassis. The Roadtrek setup has the LP tank fill behind the license plate which is directly above the hitch receiver. Brilliant design! I do not want to add any type of hitch carrier and want genset permanently mounted. Honda 2000 or 2200.
If I use a 3X3 or 3X2 angle iron clamped between the existing hitch and frame extending out about a foot beyond the rear of the camper, I can raise the generator box about 2 1/2' above the back bumper with 2X2 square tubing. Which would give access to the LP fill and make it easier to back into some spots.
I have done the Honda in a box 5 times now and have no issues with that.
See any flaws with this idea? Any and all input, thoughts, ideas or wise cracks greatly appreciated.
I would like to assemble all the idiots who locate things on RVs. I have a stabilizer jack in back of my door step. Can't get to it with step up or down. Have a stinky slinky storage tube so far under the trailer I have to get down on knees to use.
Your generator weights less than 50 pounds so weight is not so much a factor but the constant Up and down from the road will tend to weaken your mount. Just build it much stronger than you think is necessary.
bgum wrote: I would like to assemble all the idiots who locate things on RVs. I have a stabilizer jack in back of my door step. Can't get to it with step up or down. Have a stinky slinky storage tube so far under the trailer I have to get down on knees to use.
They built these Roadtreks for decades, they are suppose to be the creme of the crop and some of what I see is of a shockingly poor design. You should see where they had the house battery.
