RV.Net Open Roads Forum: Tech Issues: No gas to cook top
 > No gas to cook top
Page of 9
enahs
Washington
Posted: 03/28/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Kids are camped at Canyonlands NP at 5400 feet. New Escape RV. Gas to all other appliances except Dometic two burner cook top. It was working just a day ago at lower elevation. Is altitude really the issue or can there be something else. Do piezo wires have to be connected (I assume they are) for gas to flow? Propane tanks are full.
'07 Chevy 3500 Dooley, CC, LT3, D/A
bgum
South Louisiana
Posted: 03/28/22 10:32am Link  |  Quote  |  Print  |  Notify Moderator
When turning the stove to light are you holding the knob down/in and pressing the striker?
jdc1
Rescue, Ca
Posted: 03/28/22 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Use a match. Worry about it later. Just go have fun.
Boon Docker
Posted: 03/28/22 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
No, the piezo assembly will not stop the gas flow.
enahs
Washington
Posted: 03/28/22 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Dometic says it is an altitude issue! Everything else on gas works fine! Is there a fix. Dometic offers nothing.
Southern California :(
Posted: 03/28/22 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
I camp at altitudes far higher than 5,400 feet...such as Saddlebag Lake in the Sierra at over 10,000 feet...and have had no propane issues due to altitutde.
CA Traveler
The Western States
Posted: 03/28/22 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Rapid turn on of the valve can cause a shutdown which protects against say a break or crash. Turn all propane and valve off. Try to start the stove top to reduce the pressure. And/or wait several hours and the regulator will bleed off the pressure. You might have another regulator for the cook top, I do.
Slowly open the valve - very slow and see it the issue is resolved.
2014 Grand Cherokee Overland
Bob
enahs
Washington
Posted: 03/28/22 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I've been RVing for decades and no altitude issue with any appliance. But here it is in the kid's new Escape 21 foot RV! And Dometic says it is an issue but offers no alternative or fix! No exchange, no nuttin. And more than a few others have the same issue.
Bob/Olallawa
Mason Co, WA/Bullhead City AZ
Posted: 03/28/22 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
If in fact you have another regulator just for the cooktop, that is where I would be looking.
Welcome to my home, that door you just broke down was there for your protection not mine.
Posted: 03/28/22 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
There is indeed a second regulator under the cooktop.
But that said. I can not for the life of me think altitude would cause an issue with it. I've never heard of such a thing.. But I'm not a professional propane guy.
Recommendations:
Electric burner (no more than one per circuit breaker)
Or a portable "Camp Stove" (Coleman to the rescue).
Page of 9
