RV.Net Open Roads Forum: Tech Issues: No gas to cook top
 > No gas to cook top
Page of 9
facalton
Mineral Bluff, GA 30559
Posted: 04/08/22 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Propane gas is heavier than natural gas. It will take a while for the propane to travel the lines to the stove. Give it up to a minute. Hold a flame next to the burner and monitor.
enahs
Washington
Posted: 04/08/22 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Quite familiar with the need to wait for gas flow. In this case, you could wait all day and nuttin. Not even a slight whiff of gas or sound of air. Confident that the regulator is shutting off gas flow entirely at high altitude. At lower elevations, stove works fine!
'07 Chevy 3500 Dooley, CC, LT3, D/A
enahs
Washington
Posted: 04/09/22 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am also wondering whether any of this is influenced by the orifice size in the burners. Though I don't know, I am guessing that this too can affect the impact of atmospheric pressure on the regulator. Got the new assembly today, so we will soon be able to do a partial comparison. But complete comparison will have to await another outing above 4500 feet. It uses the same R60 regulator. Can only hope some changes have been made.
JBarca
Radnor, Ohio, USA
Posted: 04/09/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure if the burner orifice size affects gas getting to the burners. Once the gas made it to the burner, then how many BTU's of heat comes out at wide open control knob setting, then yes the orifice size would affect this. The gas control knob for each burner is a variable orifice as it relates to the amount of gas flowing to the burner. Since you can adjust the burner knob from closed all the way to wide open, one would think if orifice size was an effect, that some level of gas would come out of the burner and light or at least smell, throughout the range of the turning the control knob changing the control valve opening.
You have the assembly, OK curious minds need to know, any chance of a few pics of the old next to the new some time? And they are using the same R60 regulator?? OK, curiosity is at an all time high now. [emoticon]
Hope the new assembly works.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
enahs
Washington
Posted: 04/09/22 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I will post some side by side pics.once the old one is pulled out. But a real test will require a return to high altitude. Though Lookout pass is nearby at 4700 feet. Lola pass is a bit further at 5300 feet. Yes, the R60 regulator is on the new part, but it’s mounting tube is continuous with the whole assembly. On the originals, the regulator is on a long tube that then attaches to the gas manifold. BTW I found that regulator is or was used on a Suburban stove assembly too.
bucky
Raleigh metro
Posted: 04/10/22 04:05am Link  |  Quote  |  Print  |  Notify Moderator
The collective knowledge of the group is amazing. I'm not smart enough to weigh in so I'm just going to buy a griddle.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
enahs
Washington
Posted: 04/10/22 09:25am Link  |  Quote  |  Print  |  Notify Moderator
I wish it were that simple. Unless you use the griddle over a campfire, you will encounter a regulator!
enahs
Washington
Posted: 04/10/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 04/10/22 12:27pm by enahs *
enahs
Washington
Posted: 04/10/22 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hafta figure how to post parts schematic/
Harvard
51.6N 114.7W
Posted: 04/10/22 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
There could also be oil in the line to the stovetop blocking the flow.
x2, which congeals when cold but flows when warmer OAT.
Page of 9
