RV.Net Open Roads Forum: General RVing Issues: Tire Load/Inflation Calculation
 > Tire Load/Inflation Calculation
Page of 5
Cummins12V98
on the road
Posted: 03/29/22 08:20am Link  |  Print  |  Notify Moderator
Chart for all GY ENDURANCE tires
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JIMNLIN
Oklahoma
Posted: 03/29/22 08:28am Link  |  Print  |  Notify Moderator
Goodyear Tire and Rubber .... weighing RVs
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up.
Goodyear knows about tires used in a trailer position and they understand the folly of over tiring a trailer (above reserve capacity recommendations) as some rv owners seem hell bent on doing.
Cummins12V98
on the road
Based on 1,500# and adding 5spi that would be running 45psi at 1,6540# capacity.
CapriRacer has suggested adding 15% to the tire weight and that would put you at 1,725# and use 50psi at 1,760# capacity.
You already inflated the tire load a bit so IMHO either 45 or 50 will be just fine.
You have been running 50 for three years how even is the tread ????????
Mike134
Elgin, IL
Posted: 03/29/22 08:34am Link  |  Print  |  Notify Moderator
/\ /\ /\ THIS will tell you the right pressure.
Don't listen to the guy down the block, who talked to his cousin, who knew a guy that read it on the internet.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Cummins12V98
on the road
Posted: 03/29/22 08:36am Link  |  Print  |  Notify Moderator
OK please tell me what YOU would do. I have about 4,500# on my GY "H" tires and the tires are not holding up with a rating of 4,805 @ 125psi. My next option is going to a "J" tire (not using Chinese made Sailun). What psi would you run as the "J" has a 6,005# capacity at 125psi.
I have a lot of REAL world experience using inflation charts getting better mileage out of my tires than most. Had ONE tire blow in WAYYY over one million miles driving and towing. Tire blew because I did not know the tread had come off.
MFL
Midwest
Posted: 03/29/22 08:37am Link  |  Print  |  Notify Moderator
rfloyd99 wrote: "Should I run the rear tires at a higher psi on this 2,500 mile trip?, Especially since I'll have a little more weight in the back of the truck?"
Yes, I would use at least 40 psi in rears, to add stability, run cooler, and a small bit better mpg. Your 1500 would have come with soft sidewall tires. Using more psi will stiffen them up.
Didn't mean to go off topic of trailer tires, but TV tires are a big part of the whole rig towing experience.
Hope you have a great trip!
Jerry
rfloyd99
Colorado & Florida
Posted: 03/29/22 08:42am Link  |  Print  |  Notify Moderator
Cummins, good question. I've been running 55 psi (I check it often) and have pulled TT maybe 12-15,000 miles on these tires.
I'm headed over to the trailer now and will carefully inspect all four tires. Unless I have some uneven wear issues, it seems that the opinions here are leaning toward 50 or 55 psi being the best choice.
Now, any ideas about that tow vehicle psi?
JimK-NY
NY
Posted: 03/29/22 09:10am Link  |  Print  |  Notify Moderator
If you have a TPMS, you might want to try an experiment. Wait for a hot Summer day with the sun beating down on the pavement. Watch what happens to the tire pressures when you start out at the cold pressure corresponding to the maximum load rating. After the tires cool, try the same experiment starting out at the maximum inflation pressure. You will likely see the roughly the same final operating pressure and may even see operating pressures higher for the tires that started out with lower pressure.
Posted: 03/29/22 09:19am Link  |  Print  |  Notify Moderator
Your truck, your trailer, with the info you've given, 50-55psi is perfect for the trailer. The slight change from 205-C to 215-D tires is not a cause to change much, if anything.
Rear wheels of the truck, I'd be in the 45psi range, possibly a bit higher if it's feeling squishy, to add stiffness and better handling to the @ss end of the truck.
Front tires, you're presumably not adding much weight, if any, from running bobtail. Possibly even a shade lighter unless you're going ham on the wdh weight transfer. Fronts I'd also be at about 45psi, possibly a bit higher as well, unless they feel "too" stiff.
This is presuming you're running P/XL typical 1/2 ton tires still. Wouldn't change much if running D or E tires, maybe a shade lower than P/XL if they feel too hard, due to thicker tire carcass having better lateral stability and less flex, comparatively.
2017 Heartland Torque T29
dedmiston
Coast to Coast
Posted: 03/29/22 11:02am Link  |  Print  |  Notify Moderator
I don't use my TPMS much because it's not a very good unit, but the data is fascinating when it's actually working. It's surprising to me that the PSI is so much higher on the sunny side of the rig than the shady side.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Page of 5
