RV.Net Open Roads Forum: Travel Trailers: Small trailer suggestions
Open Roads Forum  >  Travel Trailers  >  Small TT's
 > Small trailer suggestions
NamMedevac 70
Reno
Posted: 04/02/22 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I down sized. Small is very good.
Reisender
NA
Posted: 04/02/22 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'll throw our 2 cents out there. We downsized from a 40 foot coach. We went to a T@B400. If you have the budget and are willing to wait for the build it is a very nice unit. Very good quality etc. Here are a few points that we are impressed and happy with.
- Balance. The trailer is designed with all the storage pretty much over or slightly behind the axle. The hitch weight changes very little with loading. Filling up the fresh tank actually lightens the hitch by about 10 pounds. The AGM batteries are mounted under the bed and slightly behind the axle. Really you can't load a lot of weight in a L@B anyway. There is just not a lot of places to put stuff.
- Hydronic heat and hot water is really nice. Really quiet and uses very little 12 volt, its also super efficient.
- Basement air and heat pump. No big gun turret on the roof. Helps with mileage of the tow vehicle (or in our case battery consumption and range)
- Fit and finish. Nice materials and very well done. Very european feel.
- Built in inverter, Lithium ready although we are staying with the AGM's
Here are a few pics. Not sure if you have been in one but worth taking a look. We tow with a fairly high performance SUV with a stiff suspension and 447 hp. Rear end squat is negligible. But heads up, Nucamp doesn't recommend using a weight distribution hitch so plan accordingly. Our trailer loaded for camping is around 3420 pounds and hitch weight around 340 pounds.
Hope you find your dream trailer. Safe travels and happy camping.
mavapa
Rome, Ga, USA
Posted: 04/02/22 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
So you tow with a Tesla? Pretty cool. I have not actually been inside a T@b. If I can convince my wife to go RVing, the 400 would be the preferred option, I think. If it ends up just me, I would probably lean towards the 320. But given the cost, I’m trying to see what else is out there.
Reisender
NA
Posted: 04/02/22 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yah. We tow with a Tesla model Y. Great tow vehicle for us.
I think a 320 would be fine for one person. I believe there is a 320 solo floor plan just for that. They discontinued it this year but I believe they can be found used. Most people with T&Bs look after them do you might find a good used unit.
Hope it works for you.
Happy camping.
Reisender
NA
Posted: 04/02/22 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
My apologies. The solo model is a T@B 400. Still worth considering. Neat floor plan.
Safe travels.
CortesCamperOH
Northeast Ohio
Posted: 05/05/22 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Coming soon(June 2022)
https://www.cortescampers.com/blog
Made in Ohio by hand with pride !
afidel
Cleveland
Posted: 05/06/22 12:14am Link  |  Quote  |  Print  |  Notify Moderator
Happy camping.
What is your Wh/mi when towing?
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
Reisender
NA
Posted: 05/06/22 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Happy camping.
Depends on highways speeds etc. Our last couple trips were on secondary highways to provincial parks. Kinda off the beaten track. Max 80 kmh and quite often slower on curvy twisty valley roads. About 270 wh per kilometre ish under those conditions. Maybe 30 to 50 percent more on other trips. Depends.
Here is a couple of shots of the data on our second last trip to Mabel Lake provincial park. Maybe 70 kilometres from our house.
This one shows the cars projected use and actual use. It was pretty cold which maybe explains the deviation.
And when I say cold, yes that is a snow squall headed across the lake. It turned out to be a nice week but we were a little concerned. No snow tires etc. [emoticon]
Wade44
Ohio Farm Country
Posted: 05/07/22 06:11am Link  |  Quote  |  Print  |  Notify Moderator
dieseltruckdriver wrote:
The Ember brand might be worth looking at. I have looked at a couple of them and they are geared towards boondockers if that interests you. They seemed to be higher build quality compared to most. I didn't look them over closely, but the floors aren't "squishy" in them. They are in most, and for me that's an instant no.
I don't think they would be lightweight though.
Seeing that "Ember" is staffed from the top down with Indiana RV Industry insiders, I am not so convinced they're higher build quality. Two that jump out at me that made the same claims were Keystone RV and Grand Design. The same bozo's were involved with both, then lined their pockets and bailed out LOL. I owned both and they were low grade garbage from day 1. Every "new" manufacturer based in the Elkhart/Goshen IN area since forever makes that claim. Its all marketing BS. None have ever reinvented the wheel nor do they care to. The Founder/COO of Ember worked for both Thor and Forest River which should tell you something. I doubt he has had some divine intervention regarding build quality. Old dogs don't learn new tricks.
* This post was edited 05/07/22 06:19am by Wade44 *
2018 Marathon H3-45
2019 GMC Sierra Denali (Toad)
2012 Grady White 271 Canyon
Caveman Charlie
Storden, MN
Posted: 05/08/22 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.scamptrailers.com/
To the original poster maybe one of these will be what you are looking for.
1993 Cobra Sunrise, 20 foot Travel Trailer.
